Full Version: XBMC Backup (RPI and others), not working
Hi
I installed this add-on, it backs up the userdata and add-ons, however i cant get it to restore, but if i manually copy the data back, any plugs i have might have the settings, but are not the correct versions i installed.
Also it doesnt backup any of the system information (timezone, keyboards).
So how do i make a real backup that i can restore when something goes wrong, this would be aimed at the Raspberry PI as i cant just do a file copy, need something i can use in the system
UPDATE
I had to do a 2 stage restore, manual file (copied backup to USB stick, then copy it to the location locally), restart then automated restore (from the same locations). The second time it had the UNC path so could do an automated restore.
Most of the issues i am seeing is because the system settings are not backed up (such as which weather to use), is there a way of backing up the system settings with this addon?
