Full Version: Audiophile Sound Quality - XBMC vs. Foobar
Pages: 1 2
@nickr - the basics of audiophile digital audio are:
- good sources (clean, low-compression aka high dynamic-range, well-recorded and played audio)
- lossless and preferably high bitrate (bitdepth x sample rate) audio formats (uncompressed LPCM, FLAC, DSD/DTS, MLP)
- digital transport - basically keeping the audio in digital form until it hits the external decoders/DACs. This means no losses in transport or analog conversion in the noisy PC environment. Regardless of the codec the signal should stay digital as long as possible through the transport chain. Decoding with lossless formats does not generally cause degradation of the signal, so where in the chain the signal is decoded isn't really relevent. It's where the D/A conversion takes place and the quality of that conversion and amplification.
There's myriad other factors involved in digital audio (jitter, dithering, noise shaping, etc) but these tend to pale in comparison to the analog side (D/A conversion, amplification, speakers, environment). If you get the above correct you are there from the digital perspective. Once it crosses the D/A boundary "normal" audiophile wisdom takes over. Then you can duke it out over speaker design, room correction, room treatments, etc.
Feeding 24/96khz digital remasters or SACD formats (DSD/DST) to a good stereo is pure bliss Smile
Conventional wisdom is that high bitrate PCM (while wonderful) is harsher but brighter while SACD formats are much more akin to analog formats (vinyl, reel-to-reel), and I tend to agree, but they are both excellent sounding.
But you must have good recordings! I've heard 128kbps mp3's that sound better than MeatLoaf SACD's.
Some recommendations:
Dire Straits - Brothers in Arms (SACD)
Pink Floyd - DSOTM (SACD)
Genesis - The Lamb Lies Down on Broadway onwards (SACD)
Queen - The Game (DVD-Audio)
Peter Gabriel - Up (SACD)
Cat Stevens - Tea for the Tillerman (SACD)
Many of these have been ripped and converted to FLAC at 24/88.2 using Weiss Saracon as a DSD->PCM converter with great results. All of the above except the last are multichannel. If you're more of a classical guy Nordic Sounds (2L) has some free samples of very well-recorded high-definition audio on their website.
For what I consider the best of BluRay audio check out Dave Matthews & Tim Reynolds - Live at Radio City in Dolby TrueHD.
Believe it or not, a cheap and quiet GPU will allow you to play incredibly detailed audio to any HDMI-capable receiver. If you care about audio I would go HDMI first. If not you will need to invest serious bucks into a USB DAC, money generally better spent on a receiver. A good receiver is built around good DAC's (Burr-Brown being considered one of the better in the mid-range). My preference is to stay digital right up to the input to the power amplifier section.
Enjoy Smile
(2012-11-26, 20:37)PedroSoares Wrote: [ -> ]I've been using XBMC on my HTPC for years for stereo music listening. On my audio system the sound I get from XBMC is really good, but when I listen to the same music track in foobar, I always get a more rich, powerful an detailed sound.
I've been struggling with this for a long time, and tried a lot of options, but never succeeded on having XBMC to perform as well as foobar.
With version 12.0 I was hoping that the new AudioEngine could resolve my problem, but it's the same.
In foobar I'm using ASIO and all the effects are disabled. The audio tracks are FLAC 16/44.
In XBMC I'm using WASAPI as output sound driver. (on previous versions, before WASAPI was available, directsound was really bad)
My HTPC setup:
  • Asus XONAR STX Audiophile sound card (equiped with an outstanding Burr-brown DAC)
  • NAD amplifier + JMLab focal floorstand
This is what I already tried without success:
  • I was using Windows 7, and read somewhere that Windows 8 had better sound. So I upgraded to win8, but it's the same. Now the boot takes much longer.
  • In windows sound settings, the sound card is setup for exclusive mode access.
  • Tried Asus drivers as well as third-party drivers for this sound card: Unified ASUS.
Does anyone know what I should do to get a better sound quality from XBMC? All suggestions are welcome.
In your advancedsettings.xml, try changing your default player to DVDPlayer instead of PAPlayer. Worked for me! Smile
[u]XBMC's Audio Engine is excellent !
By evaluating some Media Player primarily to manage my picture and video libraries I also tested the audio functionality as well. (HTPC, W7 on SSD)
By surprise I figured out that XBMC's new audio engine is very competitive ie. to Foobar and JRiver as well .
By comparing these players in WASAPI exclusive mode and at same loudness level, resulting sound quality is almost the same. There are of course minor differences but I would rate it as a question of personal taste.
XBMC's Audio Engine enables (on my audio setup) a very realistic soundstage and an impression of to be there (live).
Setup: HTPC --> ar-t Legato USB/SPDIF --> Lyngdorf TDAI-2200 --> Piega Coax 90.2, FLAC, 44,1/16)
As WinAmp is about to shut down, I guess XBMC could become an excellent successor even for primary audiophile users as well.
Compared to other Player I also like the implementation of the GUI, IPad-remote and the very fast start (autostart) of XBMC.
Provided not all Files are tagged appropriately - especially in my case - it is also of great help to have the File/Library mode available.
So, in summary: well done!
Todun
Question to the audio engine development team
For many good reasons I recently tested an external SSD (Samsung 840 EVO) against normally used NAS/LAN on my HTPC (music library).
Besides SQ improvements I also realised that the SSD seems to be active only on short cycles and mainly between the tracks played.
Question: what kind of buffering (size) is implemented on XBMC's audio engine?
Setup: HTPC Intel i3, with 8GB Ram, Win 7, XBMC 12.3, USB 3 --> SSD
Thanks,
Todun
My HTPC setup:
 Hey all - found this duscussion after much searching because I've found exactly the same thing, with pretty much the same hardware.
I've been using Kodi for a couple of years, after more than a decade with Foobar, because it's such a blast being able to browse my music library with an MCE remote (red button/F1 mapped to start Kodi).
However, recently, shortly after buying new speakers (Q-acoustics 2020i), I played an album (Jazz, FLAC) in Foobar that i know well - the difference was obvious and exactly as the OP describes (and I don't need no steenking ABX test to be certain).
I had just ASSUMED that Kodi/WASAPI and Foobar/ASIO (or WASAPI for that matter) were treating the bit-streams pretty much identically.
The only DSP enabled in Foobar is its volume control/attenuation slider, and the Windows one works by default with WASAPI and hence Kodi (for me a digital volume control is a necessity). And yes, I was careful to level-match when comparing the players.
Simple digital attenuation should be be transparent with either of them, assuming their 'engines' are processing at 24 bit (or 32 float). With properly functioning 24-bit hardware and software, c. 48dB of attenuation with no truncation of 16-bit audio is possible, but c. 30dB (i.e. volume control over that range) is actually plenty for most people's needs (I doubt that much attenuation of 24-bit / hi-res recordings will be audible either, at least for all but the most extremely revealing gear), and most decent interfaces have 100dB S/N or better on their analogue sides these days - the Essence STX is well over 110 dB.
Tried absolutely everything with Kodi, but just about given up now, resigned to having to use Foobar for serious listening (it has MCE remote buttons mapped to basic transport controls and volume, but it's back to drag-and-dropping files) and leaving Kodi for casual/social/background listening (and video/movies, of course).
BTW, a while back I ALSO found that Kodi isn't perfectly gapless no matter what the system settings are - a glitch is sometimes audible, even with wavs and lossless, and this is confirmed with sine wave test tones. Foobar will play a sequence of these utterly seemlessly, as if they're a single file (and almost manages to  be perfectly gapless with MP3 et al)
Asus P8Z77 / i5 2500K (data/media on 2 x 500GB WD HDD's in RAID 0)
Asus Xonar Essence STX
pair of SMSL SA-36A Pro amps (TI TPA3118 d-class)
Q Acoustics 2020i stereo pair / modified JPW passive band-pass woofer
ETA > apologies for 'necroing' such an old thread, but I noticed it started just after AudioEngine - which seemed to promise to bring Kodi up to Foobar, JRiver et al's standards - started to be included in most builds. Would have been nice if Kodi and Foobar coders had collaborated.
Hi all!
Well I think I've read everything related to Foobar on Kodi's forum. Took me a while... but that was interesting. Especially this thread.
When it comes to listen music on XMBC or Foobar, personally I hear a difference. I'm using foobar with a DAC: PS Audio "Nuwave".
That DAC is linked to my PC by USB, the "Nuwave" 's USB is asynchronous so I don't have any jitter.
I'm also using Asio and Kernel or the usb driver given by PS Audio. Both work fine.
The PS Audio driver is excellent, but sometimes (Jazz and Classic) I use kernel because it's "opening" the specter in
the treble or high (don't know which word to use. I apologize for my poor english... I'm french btw! haha)
The DAC is connected to a Naim amplifier: "NAIT-XS/2". And the amplifier is feeding my Prame "Antares" speakers (bi-wiring)
Wasapi on the other hand sounds a bit crappy IMHO. And this is the reason why I still prefer to use Foobar instead of XBMC.
When Foobar is correctly settled (No replay gain, 24 bit output, Buffer length as low as possible, No DSP (of course!!!), etc...)
the sound is just amazing. I mainly listen lossless music when it's possible.
So everything was perfect to me, until I bought a 4K HDR TV (Panasonic TX-58DX780)
First I was forced to change my graphic board: Geforce GTX 1060 3Go (I don't play games, so no need for a 6Go)
Then I had to learn how to use MadVR, MPC-BE, the Lav Filters... and Kodi/XBMC.
And now that everything is working really great. I would like to use Foobar2000 as an external player on Kodi.
But it seems it's quite tricky. Associating Foobar to XMBC is the last thing I have to achieve to reach my acme. lol
So as you can read, I'm desperate to use Foobar with XMBC. If you guys are having any solution. I would be glad to read you.
Cheers.
Corto (Maltese)    Wink
Pages: 1 2
