Full Version: problem with universal scraper for movies
Hi
I seem to be having problems with the universal scrapers for movies. I did a new install last night and it's not finding some of my films. Mostly the star wars ones. They are nnamed correctly from imdb.
It was all working fine last week but now I can't get it to find them. This is on 2 systems.
Any ideas?
I'll post a log if needed when I get in from work.
Matt
Log here.
http://www.filefactory.com/file/6qaf6mrszewz/n/xbmc_log
Had to put it here as it was to big for pastebin
Hi
I seem to be having problems with the universal scrapers for movies. I did a new install last night and it's not finding some of my films. Mostly the star wars ones. They are named correctly from imdb.
It finds them all if i use themoviedb scrapper but i cant get that one to do UK certs. and it worked before.
Any ideas?
Log here.
On how many more places are you going to post your problem?
(2012-11-30, 20:24)matt77303 Wrote: [ -> ]... They are named correctly from imdb.
Search forums for thread titles with "imdb" from the past week.
(2012-12-01, 01:03)olympia Wrote: [ -> ]On how many more places are you going to post your problem?
thanks for your help.
I posted in the general section from work not knowing there was a separate section for scrapers. so I reposted in the correct section when I got home.
thanks
Matt
...and don't forget about your post in the official thread of the Universal Scraper either. In any case the problem should be fixed by now.
(2012-12-01, 08:58)olympia Wrote: [ -> ]...and don't forget about your post in the official thread of the Universal Scraper either. In any case the problem should be fixed by now.
Thanks for fixing.
The only problem is now there is no info for the film companies?
Matt
Correct. Thanks for the feedback. Will fix this up soon.
(2012-12-01, 21:01)olympia Wrote: [ -> ]Correct. Thanks for the feedback. Will fix this up soon.
Film companies now working great. I've a couple of films that don't have cert information. Is there a way to edit these to include the missing data?
When I was using ember media manager I could just edit the .nfo file but now I'm using this there is no nfo to edit.
Matt
(2012-12-03, 20:39)matt77303 Wrote: [ -> ]
Matt
What would help most is adding the information on TMDb so everyone could benefit Smile
After you added it you could refresh the movie after about two days
I looked at that but what confused me was the that film was showing up as a PG.
But XBMC picks it up as a UK:A
http://www.themoviedb.org/movie/85-raide...e-lost-ark
Must be a error somewhere but now sure if its with xbmc or tmdb
Matt
Or else an error on your (...and silliness on IMDb) side... Smile
...you are scraping from IMDb, not from TMDb where the first UK rating is indeed 'A'.
+1 that man.
That got it, The more you look at it the more you realize how clever this scraper is.
Thanks bud
Matt
