2012-12-01, 07:51
I am compiling XBMC for arm1136ej-s and architecture is armv6. my configuration is shown below
./configure --host=armv6j-marvell-linux-gnueabi --build=i486-linux-gnu --with-arch=arm --with-cpu=arm1136j-s --prefix=/usr --exec-prefix=/usr --sysconfdir=/etc --datadir=/usr/share GIT_REV=0a59a1f --disable-debug --disable-optimizations --disable-gl --enable-gles --disable-sdl --enable-openmax --disable-vdpau --disable-vaapi --disable-crystalhd --disable-xvba --disable-vdadecoder --disable-vtbdecoder --disable-tegra --disable-profiling --disable-joystick --enable-libcec --enable-rpi-cec-api --enable-udev --disable-libusb --disable-goom --disable-rsxs --disable-projectm --disable-x11 --disable-xrandr --disable-ccache --disable-alsa --disable-pulse --enable-rtmp --enable-samba --enable-nfs --enable-afpclient --enable-libvorbisenc --enable-ffmpeg-libvorbis --enable-libmp3lame --enable-dvdcss --disable-mid --disable-hal --enable-avahi --enable-airplay --enable-airtunes --enable-non-free --disable-asap-codec --enable-webserver --enable-optical-drive --enable-libbluray --enable-texturepacker --with-texturepacker-root=/home/OpenELEC/OpenELEC.tv/build.OpenELEC-Marvell.arm-devel/toolchain --with-toolchain=/home/OpenELEC/OpenELEC.tv/build.OpenELEC-Marvell.arm-devel/toolchain --disable-external-libraries --enable-external-ffmpeg --with-platform=raspberry-pi --enable-player=omxplayer --with-sysroot=/home/OpenELEC/OpenELEC.tv/build.OpenELEC-Marvell.arm-devel/toolchain/armv6j-marvell-linux-gnueabi/sysroot/usr/lib
when i compile i get the following error.
CPP xbmc/cores/AudioEngine/Utils/AEConvert.o
Utils/AEConvert.cpp: In static member function 'static unsigned int CAEConvert::S16LE_Float(uint8_t*, unsigned int, float*)':
Utils/AEConvert.cpp:173:28: error: inconsistent operand constraints in an 'asm'
make[2]: *** [Utils/AEConvert.o] Error 1
Any help please
Thanks,
Haresh
Any help please
Thanks,
Haresh
