Since I started using xbmc I have held my normal tv-series and nature, reality ect. apart. With Frodo Beta I tried Smart Playlists which works fine, but for everything to be ideal was to get the tv-series as a submenu item.
Is this possible in any way?
Yep, you just need a skin add-on that supports custom menu items. Might need to manually install the skins, since I don't think we have any added yet to the Frodo add-on repo.
(2012-12-03, 23:04)Ned Scott Wrote: [ -> ]Yep, you just need a skin add-on that supports custom menu items. Might need to manually install the skins, since I don't think we have any added yet to the Frodo add-on repo.
Thanks, going to look around for a skin that has it.
When I was on Eden, I used the Aeon skin which has it.
I just migrated to Frodo, going to give it a try myself.
