Full Version: Xbmc remote through different routers
Hi!
So, I recently built myself a HTPC and is using XBMC with a keyboard and a mouse. And I want to use the android app as a remote, But I've run into some problems.
I've done everything according to the guide, but cant get the remote to work. Here is my network setup:
First of all i have my main modem/ router which my phone is connected to through WiFi. Then i have a router(not wireless), connected by cable to the modem. After that it goes to a switch and then to my Htpc all by cable.
So, is it possible to connect to my htpc even through it's on another router? And if it is, how do i find the IP? Conecting through the usual 3G network doesn't seem to work either.
