i can't start XBMC on ipad 2 iOS 4.3.3.
in xbmc.log i see "ERROR: SQL: SQL error or missing database"
help me please to launch this app
wow, a single line xbmc.log, I've never see that.
good sense of humor ! tnx!
I thought... other lines were useless...
but ok, that's it:
"01:22:20 T:805195776 NOTICE: -----------------------------------------------------------------------
01:22:20 T:805195776 NOTICE: Starting XBMC (12.0-BETA1 Git:20121114-25bb46a), Platform: Darwin iOS (11.0.0 iPad2,2, Version 4.3.3 (Build 8J2)). Built on Nov 14 2012
01:22:20 T:805195776 NOTICE: special://xbmc/ is mapped to: /Applications/XBMC.app/XBMCData/XBMCHome
01:22:20 T:805195776 NOTICE: special://xbmcbin/ is mapped to: /Applications/XBMC.app/XBMCData/XBMCHome
01:22:20 T:805195776 NOTICE: special://masterprofile/ is mapped to: /var/mobile/Library/Preferences/XBMC/userdata
01:22:20 T:805195776 NOTICE: special://home/ is mapped to: /var/mobile/Library/Preferences/XBMC
01:22:20 T:805195776 NOTICE: special://temp/ is mapped to: /var/mobile/Library/Preferences/XBMC/temp
01:22:20 T:805195776 NOTICE: special://frameworks/ is mapped to: /Applications/XBMC.app/Frameworks
01:22:20 T:805195776 NOTICE: The executable running is: /Applications/XBMC.app/XBMC
01:22:20 T:805195776 NOTICE: Local hostname: ZHANTMAILRU-IPAD
01:22:20 T:805195776 NOTICE: Log File is located: /var/mobile/Library/Preferences/xbmc.log
01:22:20 T:805195776 NOTICE: load settings...
01:22:20 T:805195776 NOTICE: special://profile/ is mapped to: special://masterprofile/
01:22:20 T:805195776 NOTICE: loading special://masterprofile/guisettings.xml
01:22:20 T:805195776 NOTICE: Getting hardware information now...
01:22:20 T:805195776 INFO: Using analog output
01:22:20 T:805195776 INFO: AC3 pass through is disabled
01:22:20 T:805195776 INFO: DTS pass through is disabled
01:22:20 T:805195776 DEBUG: Error: Requested setting (audiooutput.passthroughaac) was not found. It must be case-sensitive
01:22:20 T:805195776 INFO: AAC pass through is disabled
01:22:20 T:805195776 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
01:22:20 T:805195776 DEBUG: CPlayerCoreConfig::<ctor>: created player DVDPlayer for core 1
01:22:20 T:805195776 DEBUG: CPlayerCoreConfig::<ctor>: created player oldmplayercore for core 1
01:22:20 T:805195776 DEBUG: CPlayerCoreConfig::<ctor>: created player PAPlayer for core 3
01:22:20 T:805195776 DEBUG: CPlayerSelectionRule::Initialize: creating rule: system rules
01:22:20 T:805195776 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtv
01:22:20 T:805195776 DEBUG: CPlayerSelectionRule::Initialize: creating rule: hdhomerun/myth/mms/udp
01:22:20 T:805195776 DEBUG: CPlayerSelectionRule::Initialize: creating rule: lastfm/shout
01:22:20 T:805195776 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtsp
01:22:20 T:805195776 DEBUG: CPlayerSelectionRule::Initialize: creating rule: streams
01:22:20 T:805195776 DEBUG: CPlayerSelectionRule::Initialize: creating rule: aacp/sdp
01:22:20 T:805195776 DEBUG: CPlayerSelectionRule::Initialize: creating rule: mp2
01:22:20 T:805195776 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvd
01:22:20 T:805195776 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvdimage
01:22:20 T:805195776 DEBUG: CPlayerSelectionRule::Initialize: creating rule: sdp/asf
01:22:20 T:805195776 DEBUG: CPlayerSelectionRule::Initialize: creating rule: nsv
01:22:20 T:805195776 DEBUG: CPlayerSelectionRule::Initialize: creating rule: radio
01:22:20 T:805195776 NOTICE: Loaded playercorefactory configuration
01:22:20 T:805195776 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
01:22:20 T:805195776 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
01:22:20 T:805195776 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
01:22:20 T:805195776 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
01:22:20 T:805195776 NOTICE: Default DVD Player: dvdplayer
01:22:20 T:805195776 NOTICE: Default Video Player: dvdplayer
01:22:20 T:805195776 NOTICE: Default Audio Player: paplayer
01:22:20 T:805195776 NOTICE: Disabled debug logging due to GUI setting. Level 0.
01:22:20 T:805195776 NOTICE: Log level changed to 0
01:22:20 T:805195776 NOTICE: Loading media sources from special://masterprofile/sources.xml
01:22:20 T:805195776 NOTICE: Running database version Addons15
01:22:21 T:805195776 NOTICE: Checking resolution 16
01:22:21 T:805195776 NOTICE: GL_VENDOR = Imagination Technologies
01:22:21 T:805195776 NOTICE: GL_RENDERER = PowerVR SGX 543
01:22:21 T:805195776 NOTICE: GL_VERSION = OpenGL ES 2.0 IMGSGX543-58.6
01:22:21 T:805195776 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.0
01:22:21 T:805195776 NOTICE: GL_EXTENSIONS = GL_OES_depth_texture GL_OES_depth24 GL_OES_fbo_render_mipmap GL_OES_mapbuffer GL_OES_packed_depth_stencil GL_OES_rgb8_rgba8 GL_OES_standard_derivatives GL_OES_texture_float GL_OES_texture_half_float GL_OES_vertex_array_object GL_EXT_blend_minmax GL_EXT_discard_framebuffer GL_EXT_read_format_bgra GL_EXT_shader_texture_lod GL_EXT_texture_filter_anisotropic GL_APPLE_framebuffer_multisample GL_APPLE_rgb_422 GL_APPLE_texture_format_BGRA8888 GL_APPLE_texture_max_level GL_IMG_read_format GL_IMG_texture_compression_pvrtc
01:22:22 T:805195776 NOTICE: Running database version Addons15
01:22:22 T:805195776 NOTICE: Running database version ViewModes4
01:22:22 T:805195776 NOTICE: Old database found - updating from version 60 to 72
01:22:22 T:805195776 ERROR: SQL: SQL error or missing database
Query: SELECT idVersion FROM version
If it was a
Debug Log there might be some more (enabled via advancedsettings.xml, so non-trivial), but it appears there's an issue with your videodatabase being corrupt. You can delete MyVideos60.db. It might pay to reload Eden on it and export to a single file/folder structure so you can reimport with Frodo.
please do not c/p logs in forum threads, read
Debug Log on how to properly report issues
APP still not working... any ideas?
