Hi Guys,
Trying to find my audio devices through aplay but it's saying it can't find the command. SSH works going into htpc but that's as far as I get. How do you find the aplay command??
Cheers.
(2012-12-03, 00:26)smcdonell Wrote: [ -> ]Hi Guys,
Cheers.
It should be in there.
try:
if that doesn't work:
sudo find / -name aplay
and see if it will find the file.
maurice118
Thanks mate. I'll give that a go.
if aplay is not there install
alsa-utils
Which means your alsa is not installed properly to begin with
sudo apt-get install alsa-utils
uNi
I know this is a stupid question but where do I find the alsa-utils? How do I install it?
* un1versal hands smcdonell a pair of READING glasses.
uNi
