2012-12-21, 15:39
2012-12-21, 18:07
Just a few general comments.
1. Timeshift buffer is currently a permanent ring buffer upto the specified limits. Much like a standard pvr. I'm going to eventually add an option for pause only.
2. Performance of timeshift seeking will be slightly quicker with local and/or SSD drive. But for most use cases it'll be negligible.
3. HD content is about 1-2MBytes per second. So 4-5GBytes an hour typically. So base space requirements on that.
4. Stuttering playback can occur depending on video playback settings. I'm still trying to figure optimal for my own machines.
5. There are definitely issues with playback after fd/rwd. Not sure where the fault lies at this stage.
6. I wouldn't call the code stable, but since its starting to be used and doesn't seem to be doing too badly I think I may merge to master in the next few weeks.
Finally there is definitely a long way to go for a truely seamless timeshift, both in tvh and xbmc. But I think by at least having something we can begin that progress.
Adam
Adam
2012-12-21, 18:17
Thank you for the explanation Adam!
Does that mean that even if i watch tv and no pauze is pressed yet, it will still writes the stream to disk?
2012-12-22, 13:40
Yes at the moment that's exactly what it means. I'll be adding some extra flexibility as we go.
Adam
Adam
2012-12-23, 13:59
I have been tasked with setting up timeshift for a friend on his box.
Almost identical setup to what I have.
I have cloned the git repo. Checked out the timeshift branch. And configured to enable timeshift.
When I then try to make and make install, I get an error 1.
Any ideas what I am doing wrong?
CC build.linux/src/timeshift.o
/tvheadend/tvheadend/src/timeshift.c: In function âtimeshift_initâ:
/tvheadend/tvheadend/src/timeshift.c:59:29: error: integer overflow in expression [-Werror=overflow]
cc1: all warnings being treated as errors
make: *** [build.linux/src/timeshift.o] Error 1
2012-12-23, 14:09
Probably a bug in my last commits, code it's a still in flux.
Just checkout the same commit you're using.
Adam
Adam
2012-12-23, 14:46
Thanks for the advice Adam
I must still be doing something wrong, cos I have tried using the commit I used, and now I get no timeshift option.
Correct me if I am wrong but the steps below are what I am doing:
1. git clone https://github.com/tvheadend/tvheadend.git
2. git checkout a420c83a0e
3. ./configure --enable-timeshift
4. make
5. make install
Any help would be greatly appreciated. I am not quite au fait with git, but will have a crack.
4. make
5. make install
2012-12-23, 14:47
using latest 3.3.218~g85bef87-dirty with timeshift.
and we have a brand new timeshift tab in tvheadend configuration.
enabled 'on demand'
works perfectly!
great work Adam.
enabled 'on demand'
works perfectly!
great work Adam.
2012-12-23, 15:09
I am using the new tab too, great work Adam. I have noticed that the fast forward and rewind option from the OSD have gone, pause still works.
Is this a xbmc, tvheadend-addon or tvheadend issue?
2012-12-23, 15:14
The on demand option doesn't do anything at the moment. I was just asking the new tab and thinking through some options I want to add.
In fact I've probably broken a few things with the new config at the moment.
Adam
Adam
2012-12-23, 15:16
Trying to get the timeshift to work from an old commit.
Cant understand where I am going wrong, if anyone can help would be extremely happy
2012-12-23, 15:18
@dd
why use an old commit?
makes no sense.
it's in development and i think Adam would me most helped with feedback on current status.
good luck with getting timeshift to work.
regards
makes no sense.
regards
2012-12-23, 15:30
When I try to use the latest I get an error as listed earlier in this thread.
Adam told me to use the same commit I have on my other box (which works), which I have tried and get no timeshift option.
Have I missed anything from below:
I'm not even sure if this is the correct way or if it is the way I did it on my own box.
Many thanks for your help.
Here is the error I get after trying the above steps:
~# apt-get install build-essential git pkg-config libssl-dev bzip2 wget
~# apt-get install libavahi-client-dev zlib1g-dev
~# git clone https://github.com/tvheadend/tvheadend.git
~# git checkout feature/timeshift
~# ./configure --enable-timeshift
~# make
~# make install
root@XBMC:~# git clone https://github.com/tvheadend/tvheadend.git
Cloning into 'tvheadend'...
remote: Counting objects: 17394, done.
remote: Compressing objects: 100% (4681/4681), done.
remote: Total 17394 (delta 13263), reused 16679 (delta 12643)
Receiving objects: 100% (17394/17394), 5.43 MiB | 623 KiB/s, done.
Resolving deltas: 100% (13263/13263), done.
root@XBMC:~# dir
Downloads Movies Music Pictures tvheadend TV\ Shows
root@XBMC:~# cd tvheadend
root@XBMC:~/tvheadend# dir
Autobuild configure data docs LICENSE man src
Autobuild.sh contrib debian lib Makefile README support
root@XBMC:~/tvheadend# git checkout feature/timeshift
Branch feature/timeshift set up to track remote branch feature/timeshift from origin.
Switched to a new branch 'feature/timeshift'
root@XBMC:~/tvheadend# ./configure --enable-timeshift
checking for cc execinfo.h ... ok
checking for cc -mmmx ... ok
checking for cc -msse2 ... ok
checking for cc getloadavg ... ok
checking for py module gzip ... ok
checking for bzip2 ... ok
checking for pkg openssl ... ok
checking for pkg zlib ... ok
checking for pkg avahi-client ... ok
Fetching dvb-scan files... done
Compiler:
Using C compiler: cc
Build for arch: i686
Binaries:
Using PYTHON: python
Options:
cwc: yes
v4l: yes
linuxdvb: yes
dvbscan: yes
timeshift: yes
avahi: yes
zlib: yes
bundle: no
dvbcsa: no
execinfo: yes
mmx: yes
sse2: yes
getloadavg: yes
py_gzip: yes
bin_bzip2: yes
ssl: yes
Packages:
openssl: 1.0.1c
zlib: 1.2.7
avahi-client: 0.6.31
Installation paths:
Prefix: /usr/local
Binaries: ${prefix}/bin
Libraries: ${prefix}/lib
Data files: ${prefix}/share
Man pages: ${datadir}/man
Final Binary:
/home/ray/tvheadend/build.linux/tvheadend
Tvheadend Data Directory:
/usr/local/share/tvheadend
root@XBMC:~/tvheadend# make
CC build.linux/src/main.o
CC build.linux/src/utils.o
CC build.linux/src/wrappers.o
CC build.linux/src/version.o
CC build.linux/src/access.o
CC build.linux/src/dtable.o
CC build.linux/src/tcp.o
CC build.linux/src/http.o
CC build.linux/src/notify.o
CC build.linux/src/file.o
CC build.linux/src/epg.o
CC build.linux/src/epgdb.o
CC build.linux/src/epggrab.o
CC build.linux/src/spawn.o
CC build.linux/src/packet.o
CC build.linux/src/streaming.o
CC build.linux/src/teletext.o
CC build.linux/src/channels.o
CC build.linux/src/subscriptions.o
CC build.linux/src/service.o
CC build.linux/src/psi.o
CC build.linux/src/parsers.o
CC build.linux/src/parser_h264.o
CC build.linux/src/parser_latm.o
CC build.linux/src/tsdemux.o
CC build.linux/src/bitstream.o
CC build.linux/src/htsp_server.o
CC build.linux/src/serviceprobe.o
CC build.linux/src/htsmsg.o
CC build.linux/src/htsmsg_binary.o
CC build.linux/src/htsmsg_json.o
CC build.linux/src/htsmsg_xml.o
CC build.linux/src/misc/dbl.o
CC build.linux/src/misc/json.o
CC build.linux/src/settings.o
CC build.linux/src/htsbuf.o
CC build.linux/src/trap.o
CC build.linux/src/avg.o
CC build.linux/src/htsstr.o
CC build.linux/src/rawtsinput.o
CC build.linux/src/iptv_input.o
CC build.linux/src/avc.o
CC build.linux/src/huffman.o
CC build.linux/src/filebundle.o
CC build.linux/src/config2.o
CC build.linux/src/lang_codes.o
CC build.linux/src/lang_str.o
CC build.linux/src/epggrab/module.o
CC build.linux/src/epggrab/channel.o
CC build.linux/src/epggrab/module/pyepg.o
CC build.linux/src/epggrab/module/xmltv.o
CC build.linux/src/plumbing/tsfix.o
CC build.linux/src/plumbing/globalheaders.o
CC build.linux/src/dvr/dvr_db.o
CC build.linux/src/dvr/dvr_rec.o
CC build.linux/src/dvr/dvr_autorec.o
CC build.linux/src/dvr/ebml.o
CC build.linux/src/dvr/mkmux.o
CC build.linux/src/webui/webui.o
CC build.linux/src/webui/comet.o
CC build.linux/src/webui/extjs.o
CC build.linux/src/webui/simpleui.o
CC build.linux/src/webui/statedump.o
CC build.linux/src/webui/html.o
CC build.linux/src/muxer.o
CC build.linux/src/muxer_pass.o
CC build.linux/src/muxer_tvh.o
CC build.linux/src/epggrab/otamux.o
CC build.linux/src/epggrab/module/eit.o
CC build.linux/src/epggrab/module/opentv.o
CC build.linux/src/epggrab/support/freesat_huffman.o
/home/ray/tvheadend/src/timeshift.c: In function âtimeshift_initâ:
/home/ray/tvheadend/src/timeshift.c:63:3: error: large integer implicitly truncated to unsigned type [-Werror=overflow]
2012-12-23, 15:54
What os is this on? Could it be related to that? I using Ubnutu 12.04
2012-12-23, 15:56
Xbmcbuntu frodo rc2
My box is rc1.
But they are both based on Ubuntu 12.10, aren't they?
My box is rc1.
