It's a bug in the gui. Something to do with the fact that the IP address pop-up and the number popup use the same window. Just enter the port that your json service runs on. Normally 80.
Hi just wondering if this works with kodi 17 or would it need to be revised or is there something else like this I can use to stop playback on one kodi and resume on another kodi thnxx
That's a good question! I'm not sure, I haven't had need to use this myself in a while. Did you ever end up trying it? It uses mostly JSON calls so as long as those haven't changed too much. Feel free to post on the github page with any issues:
https://github.com/robweber/script.sendto
Hi, I have a question do you plan on updating the addon? it worked on kodi 18 i used it alot, but no luck on kodi 19.
