2012-12-05, 02:04
I started on a little project of my own, I am still basic learner of PHP and haven't done too much in it so it might be a bit messy when it comes to the coding, any advise on those points is most welcome.
I started with this idea as I started sharing library between multiple devices through a sql server, I then got the idea that it would also have to be possible to extract that information into a webpage that has acces to the sql server.
It excists out of one page and a included file for database connection.
So far it is only made to show video library, mainly because I don't have any music imported in XBMC yet.
Main file shows the series that are stored on my pc and and when the "?show=" parameter is included it shows the episodes of those shows and basic informatie with download links to the shows.
Reason I use this is to download shows from my pc to other pc's when not at home.
I still desire to include some basic remote features, mainly to refresh or clean library, just don't have a clue how to start on that part yet.
If anyone here can see some points that might be improved I'd be glad to hear that.
Best way I learn stuff is to actually work with it and put it to use, and since this does offer some basic uses for me its a great start.
I included the codes I used below, can't actually show a site with this code since I would be illegally sharing files and I don't think anyone here would apreciate that.
inc/db.inc.php
index.php
inc/db.inc.php
PHP Code:
<?php
$host="localhost";
$username="username";
$password="password";
$database="myvideos##";
mysql_connect("$host","$username","$password");
mysql_select_db("$database");
index.php
PHP Code:
<?php
include('./inc/db.inc.php');
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<title>XBMC Library</title>
<style>
body {
color: #2F2F2F;
font-size: small;
font-family: arial, verdana, tahoma, sans-serif;
a {
color: #39F;
text-decoration: none;
a:hover {
color: #00F;
text-decoration: underline;
</style>
</head>
<body>
<table border="1">
<?php
if(empty($_GET['show'])) {
$result = mysql_query("SELECT * FROM tvshow ORDER BY c00"); //sorted from a-z on title
while($row = mysql_fetch_array($result))
$showID="$row[idShow]";
echo "<tr>";
echo "<td>" . "<a href='?show=$showID'>" . "$row[c00]" . "</a>" . "</td>";
echo "<td NOWRAP>" . "$row[c05]" . "</td>";
echo "<td>" . "$row[c08]" . "</td>";
echo "<td>" . "$row[c01]" . "</td>";
echo "</tr>";
} else {
$result = mysql_query("SELECT * FROM tvshow WHERE idShow=$_GET[show]");
$seasons = mysql_query("SELECT * FROM seasons WHERE idShow=$_GET[show]");
$episode = mysql_query("SELECT * FROM episode WHERE idShow=$_GET[show] ORDER BY c12 AND c13");
$row = mysql_fetch_array($result);
$ssn = mysql_num_rows($seasons)-2; //Seasons start at -1
echo "<h2><a href='./'>< TV shows</a></h2>";
echo "<tr>";
echo "<h1>$row[c00]</h1>";
echo "<img src='http://thetvdb.com/banners/graphical/$row[c12]-g.jpg' border='0'><br>"; //banners loaded from thetvdb site.
echo "<h3>$row[c01]</h3>";
while($ep = mysql_fetch_array($episode)) {
$local = "E:\Downloads\Sorted\Series";
$location = "$ep[c18]";
$ftp = str_replace($local, "ftp://piko.pikorimugadgets.nl", "$location"); //Replaces local path with the ftp path to files.
echo "<tr>";
echo "<td nowrap='nowrap'>" . "<a href='$ftp'>Season: $ep[c12] - Episode $ep[c13]</a>" . "</td>";
echo "<td>" . "$ep[c01]" . "</td>";
</table>
<?php
///Error checking
if($result !== false){
//fetchen
else{
echo mysql_error();
</body>
<?php
mysql_close();
</html>
