2012-12-05, 02:14
HI,
I'm trying to mod a skin to allow a user to select the default view, rather than having to set them individually for all items (such as TV shows and seasons). The skin I'm doing this on is Quartz V3, but I assume the same procedure would apply to all skins.
Anyway, I have altered the defaultcontrol item in myVideoNav.xml, deleted the myviews db and also guisettings, but still the standard list view (50) persists. It doesn't matter what view I use, it always uses 50.
Is it possible to change the default or am I doing something wrong. Or should I be approaching this from another angle?
The next part was to code this up as a user setting, so I'm also assuming that using a skin setting property within the defaultcontrol tag is ok?
