Full Version: [SOLVED] [OS X] Frodo Beta 1: Issue using MySQL
I am trying, without success, to setup MySQL to access my video library. I have successfully installed and setup MySQL:
CREATE USER 'xbmc' IDENTIFIED BY 'xbmc';
GRANT ALL ON *.* TO 'xbmc';
CREATE DATABASE xbmc_video DEFAULT CHARACTER SET latin1 COLLATE latin1_general_ci;
FLUSH PRIVILEGES;
I can access MySQL locally on the MySQL server machine:
mysql -u root -p
Enter password:
Welcome to the MySQL monitor.  Commands end with ; or \g.
Your MySQL connection id is 754
Server version: 5.5.28-log Source distribution
Copyright (c) 2000, 2012, Oracle and/or its affiliates. All rights reserved.
Oracle is a registered trademark of Oracle Corporation and/or its
affiliates. Other names may be trademarks of their respective
owners.
Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
mysql> select user,host from mysql.user;
| user | host      |
| xbmc | %         |
| root | 127.0.0.1 |
| root | ::1       |
|      | WebServer |
| root | WebServer |
|      | localhost |
| root | localhost |
7 rows in set (0.00 sec)
mysql> show grants for 'xbmc';
| Grants for xbmc@%        |
| GRANT ALL PRIVILEGES ON *.* TO 'xbmc'@'%' IDENTIFIED BY PASSWORD '*EC4F5173DE994BFEAB7040A4A32B4ED6DE26F6F0' |
1 row in set (0.00 sec)
mysql> SHOW DATABASES;
| Database           |
| information_schema |
| mysql              |
| performance_schema |
| test               |
| xbmc_video         |
5 rows in set (0.00 sec)
I can access MySQL remotely from a client machine on the network:
/usr/local/mysql/bin/mysql -h 10.0.1.250 -P 3306 -u xbmc -p
Enter password:
Your MySQL connection id is 755
owners.
| user | host      |
| xbmc | %         |
| root | 127.0.0.1 |
| root | ::1       |
|      | WebServer |
| root | WebServer |
|      | localhost |
| root | localhost |
7 rows in set (0.01 sec)
| Grants for xbmc@%        |
1 row in set (0.01 sec)
| Database           |
| mysql              |
| test               |
| xbmc_video         |
After setting up MySQL I exported my video library to a single file, deleted MyVideos72.db, textures13.db and Thumbnails folder. I then modified advancedsettings.xml:
<advancedsettings>
    <fullscreen>true</fullscreen>
    <splash>false</splash>
    <videodatabase>
        <type>mysql</type>
        <host>10.0.1.250</host>
        <port>3306</port>
        <user>xbmc</user>
        <pass>xbmc</pass>
        <name>xbmc_video</name>
    </videodatabase>
    <Videolibrary>
        <cleanonupdate>true</cleanonupdate>
    </Videolibrary>
    <video>
        <!-- Number of seconds to ignore at video start after which a resume point is created -->
        <ignoresecondsatstart>15</ignoresecondsatstart>
    </video>
</advancedsettings>
Now when I run XBMC I get the error "service.skin.widgets":
And when I attempt to import the exported video library, nothing happens. What am I missing?
Debug Log
"CREATE DATABASE xbmc_video DEFAULT CHARACTER SET latin1 COLLATE latin1_general_ci;"
This is your main mistake. Since before Eden, you do not have to create a database, XBMC will do it for you. This was highlighted in the Debug Log as well:
20:51:35 T:140735251779968 NOTICE: Old database found - updating from version 0 to 72
20:51:35 T:140735251779968 ERROR: SQL: The source database was unexpectedly empty.
Cheers,
Jonathan
(2012-12-05, 04:52)jmarshall Wrote: [ -> ]"CREATE DATABASE xbmc_video DEFAULT CHARACTER SET latin1 COLLATE latin1_general_ci;"
This is your main mistake. Since before Eden, you do not have to create a database, XBMC will do it for you. This was highlighted in the debug log as well:
Cheers,
Jonathan
That was it. All I had to do was "DROP xmbc_video", restart XBMC and I am now able to import. Thanks for your help. I was looking at the link to http://www.stephenandrewdesigns.com/pogo...L7In6WTb8s in http://wiki.xbmc.org/index.php?title=HOW...g_up_MySQL. That pogoplug link needs to be updated.
Thanks for the heads up. I'll make an updated copy of the pogoplug instructions directly on the wiki.
(2012-12-05, 06:21)Ned Scott Wrote: [ -> ]Thanks for the heads up. I'll make an updated copy of the pogoplug instructions directly on the wiki.
Ned,
If you like here is an updated instructions for installing and setting up MySQL on the Pogoplug:
  1. Install MySQL:
    sudo pacman -Syu mysql
  2. sudo vi /etc/mysql/my.cnf
    In the [mysqld] section, comment out skip-networking and add skip-name-resolve.
  3. Start MySQL:
    If you are using systemd execute: sudo systemctl start mysqld
    If you are using initscripts execute: sudo /etc/rc.d/mysqld start
    If the MySQL fails to start check /var/lib/mysql folder and the contents of /var/lib/mysql that the ownership is mysql:mysql. If you need to fix the ownership:
    sudo chown mysql:mysql /var/lib/mysql/*
  4. Execute MySQL (no root password):
    mysql -u root
  5. Create the xbmc user with a password = xbmc:
    quit
  6. Start mysqld at boot time:
    If you are using systemd execute: sudo systemctl enable mysqld
    If you are using initscripts: Add mysql to list of DAEMONS in /etc/rc.conf.
(2012-12-08, 09:04)Ned Scott Wrote: [ -> ]Awesome, thanks!
HOW-TO:Sync multiple libraries/Setting up MySQL/ALARM (wiki)
Glad I could contribute. I made a couple of changes to my instructions. Would you put them on the Wiki. Thanks.
