Full Version: Frodo Beta 2: Failed to get size of gamma for output default
I have updated from Eden to Frodo Beta 2 yesterday and everything seemed to go fine.
Today when I try to log in as xbmc user, the screen gets blank for a few seconds and the desktop login window appears again.
This is the crash log:
############## XBMC CRASH LOG ###############
################ SYSTEM INFO ################
Date: Wed Dec  5 09:00:04 CET 2012
XBMC Options:
Arch: i686
Kernel: Linux 3.0.0-27-generic-pae #44-Ubuntu SMP Tue Oct 16 17:13:32 UTC 2012
Release:
    Distributor ID:    Ubuntu
    Description:    Ubuntu 11.10 - XBMCbuntu
    Release:    11.10
    Codename:    oneiric
############## END SYSTEM INFO ##############
############### STACK TRACE #################
gdb not installed, can't get stack trace.
############# END STACK TRACE ###############
################# LOG FILE ##################
09:00:04 T:3021174544  NOTICE: -----------------------------------------------------------------------
09:00:04 T:3021174544  NOTICE: Starting XBMC (12.0-BETA2 Git:Unknown), Platform: Linux (Ubuntu 11.10 - XBMCbuntu, 3.0.0-27-generic-pae i686). Built on Dec  2 2012
09:00:04 T:3021174544  NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
09:00:04 T:3021174544  NOTICE: special://xbmcbin/ is mapped to: /usr/lib/xbmc
09:00:04 T:3021174544  NOTICE: special://masterprofile/ is mapped to: /home/xbmc/.xbmc/userdata
09:00:04 T:3021174544  NOTICE: special://home/ is mapped to: /home/xbmc/.xbmc
09:00:04 T:3021174544  NOTICE: special://temp/ is mapped to: /home/xbmc/.xbmc/temp
09:00:04 T:3021174544  NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
09:00:04 T:3021174544  NOTICE: Local hostname: HTPC
09:00:04 T:3021174544  NOTICE: Log File is located: /home/xbmc/.xbmc/temp/xbmc.log
############### END LOG FILE ################
############ END XBMC CRASH LOG #############
And the xbmc.log:
And finally the .xsession-errors file:
Running X session wrapper
Loading profile from /etc/profile
Loading profile from /home/xbmc/.profile
Loading resource: /etc/X11/Xresources/x11-common
Loading X session script /etc/X11/Xsession.d/20x11-common_process-args
Loading X session script /etc/X11/Xsession.d/30x11-common_xresources
Loading X session script /etc/X11/Xsession.d/40x11-common_xsessionrc
Loading X session script /etc/X11/Xsession.d/50x11-common_determine-startup
Loading X session script /etc/X11/Xsession.d/52libcanberra-gtk3-module_add-to-gtk-modules
Loading X session script /etc/X11/Xsession.d/60x11-common_localhost
Loading X session script /etc/X11/Xsession.d/60x11-common_xdg_path
Loading X session script /etc/X11/Xsession.d/70gconfd_path-on-session
Loading X session script /etc/X11/Xsession.d/75dbus_dbus-launch
Loading X session script /etc/X11/Xsession.d/90consolekit
Loading X session script /etc/X11/Xsession.d/90x11-common_ssh-agent
Loading X session script /etc/X11/Xsession.d/99x11-common_start
/usr/lib/xbmc/xbmc-xrandr: Failed to get size of gamma for output default
Segmentation fault
Crash report available at /home/xbmc/xbmc_crashlog-20121205_090002.log
Segmentation fault
Crash report available at /home/xbmc/xbmc_crashlog-20121205_090003.log
Segmentation fault
Crash report available at /home/xbmc/xbmc_crashlog-20121205_090004.log
XBMC has exited uncleanly 3 times in the last 3 seconds.
Something is probably wrong
Nice message at the end...
Really? Log snippets? install gdb as well to get stacktraces. and pastebin full debug logs and crashlogs.
see http://wiki.xbmc.org/index.php?title=Log..._Debugging
uNi
No, these are the full logs, no snippets.
Then your xbmc install and possibly even drivers are screwed.
rename your guisettings.xml if that doesnt do it.
Use the xvba ppa (see my sig top link) and reinstall XBMC and your video drivers and install gdb < really install gdb. in any case.
uNi
Renaming guisettings.xml did not do it, so I
- installed XBMC from the XVBA-PPA repo
- installed gdb
- updated the video drivers
- rebooted
The problem remains the same.
xbmc.log
14:13:05 T:3017238288  NOTICE: -----------------------------------------------------------------------
14:13:05 T:3017238288  NOTICE: Starting XBMC (12.0-BETA2 Git:Unknown), Platform: Linux (Ubuntu 11.10 - XBMCbuntu, 3.0.0-27-generic-pae i686). Built on Dec  3 2012
14:13:05 T:3017238288  NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
14:13:05 T:3017238288  NOTICE: special://xbmcbin/ is mapped to: /usr/lib/xbmc
14:13:05 T:3017238288  NOTICE: special://masterprofile/ is mapped to: /home/xbmc/.xbmc/userdata
14:13:05 T:3017238288  NOTICE: special://home/ is mapped to: /home/xbmc/.xbmc
14:13:05 T:3017238288  NOTICE: special://temp/ is mapped to: /home/xbmc/.xbmc/temp
14:13:05 T:3017238288  NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
14:13:05 T:3017238288  NOTICE: Local hostname: HTPC
14:13:05 T:3017238288  NOTICE: Log File is located: /home/xbmc/.xbmc/temp/xbmc.log
xbmc_crashlog
Date: Wed Dec  5 14:13:05 CET 2012
XBMC Options:
Arch: i686
Release:
    Release:    11.10
    Codename:    oneiric
=====>  Core file: /home/xbmc/core (2012-12-05 14:13:05.812493739 +0100)
[New LWP 1669]
[Thread debugging using libthread_db enabled]
Core was generated by `/usr/lib/xbmc/xbmc.bin --standalone'.
Program terminated with signal 11, Segmentation fault.
#0  0xb6364de4 in snd_config_get_type () from /usr/lib/i386-linux-gnu/libasound.so.2
Thread 1 (Thread 0xb3d76710 (LWP 1669)):
#1  0xb6367814 in ?? () from /usr/lib/i386-linux-gnu/libasound.so.2
#2  0xb63684a3 in snd_config_copy () from /usr/lib/i386-linux-gnu/libasound.so.2
#3  0x0879083d in CAESinkALSA::EnumerateDevicesEx(std::vector<CAEDeviceInfo, std::allocator<CAEDeviceInfo> >&) ()
#4  0x0877bf51 in CAESinkFactory::EnumerateEx(std::vector<AESinkInfo, std::allocator<AESinkInfo> >&) ()
#5  0x08781fe8 in CSoftAE::CSoftAE() ()
#6  0x0877a7d5 in CAEFactory::LoadEngine(AEEngine) ()
#7  0x0877a940 in CAEFactory::LoadEngine() ()
#8  0x08bee546 in CApplication::Create() ()
#9  0x08c8febc in XBMC_Run ()
#10 0x082d7056 in main ()
.xsession-errors
Segmentation fault (core dumped)
Crash report available at /home/xbmc/xbmc_crashlog-20121205_141300.log
Crash report available at /home/xbmc/xbmc_crashlog-20121205_141303.log
Crash report available at /home/xbmc/xbmc_crashlog-20121205_141305.log
XBMC has exited uncleanly 3 times in the last 8 seconds.
When i try to start XBMC from the terminal:
Error: unable to open display
FEH.py: cannot connect to X server
I think I will have to re-install from scratch....
plz try moving your ~/.xbmc
cd
mv .xbmc .xbmc.bak
if this doesn't work, provide the output of:
apt-cache policy libasound2 xbmc
Just to make sure we cover the basics.. + what wsnipex said.
Make sure any current /etc/asound.conf or .asoundrc are renamed as well.
uNi
Thanks. Will try that next time in case the error occurs again.
This time I decided to reinstall from scratch using XBMCbuntu 12 Beta 1 (as Beta 2 is not yet available) and updated this installation to Beta 2.
Now everything works fine again.
Yes Big Grin glad to see you worked it out using the sledgehammer method.
uNi
Takes about half an hour normally...
I would have waited longer, but I really need a working XBMC today.
I'm facing the same problem again after having added my music to the database and installing a skin (xperience 1080).
No asound.conf or .asoundrc in /etc, renaming guisettings.xml did not help, nor did renaming .xbmc folder.
Will post the log files tomorrow, I'm having enough of XBMC for now.
use default skin if same problems persist you know its not skin, skins are known to cause issues anyway and when you have problems you want everything to be more or less default.
uNi
.xsession-errors:
*** glibc detected *** /usr/lib/xbmc/xbmc.bin: free(): invalid pointer: 0xb61a6ef0 ***
======= Backtrace: =========
/lib/i386-linux-gnu/libc.so.6(+0x75ee2)[0xb5ceeee2]
/usr/lib/i386-linux-gnu/libasound.so.2(snd_config_substitute+0x6d)[0xb61a160d]
/usr/lib/i386-linux-gnu/libasound.so.2(+0x22158)[0xb61a3158]
/usr/lib/i386-linux-gnu/libasound.so.2(snd_config_update_r+0x229)[0xb61a3dc9]
/usr/lib/i386-linux-gnu/libasound.so.2(snd_config_update+0x48)[0xb61a4358]
/usr/lib/xbmc/xbmc.bin(_ZN11CAESinkALSA18EnumerateDevicesExERSt6vectorI13CAEDeviceInfoSaIS1_EE+0x2179)[0x877be29]
/usr/lib/xbmc/xbmc.bin(_ZN14CAESinkFactory11EnumerateExERSt6vectorI10AESinkInfoSaIS1_EE+0x61)[0x87654e1]
/usr/lib/xbmc/xbmc.bin(_ZN7CSoftAEC1Ev+0x4c8)[0x876b578]
/usr/lib/xbmc/xbmc.bin(_ZN10CAEFactory10LoadEngineE8AEEngine+0x55)[0x8763d65]
/usr/lib/xbmc/xbmc.bin(_ZN10CAEFactory10LoadEngineEv+0x120)[0x8763ed0]
/usr/lib/xbmc/xbmc.bin(_ZN12CApplication6CreateEv+0x48f)[0x8bd0dbf]
/usr/lib/xbmc/xbmc.bin(XBMC_Run+0x3c)[0x8c71e6c]
/usr/lib/xbmc/xbmc.bin(main+0xf6)[0x82d5366]
/lib/i386-linux-gnu/libc.so.6(__libc_start_main+0xf3)[0xb5c924d3]
/usr/lib/xbmc/xbmc.bin[0x82d7fc1]
======= Memory map: ========
08048000-0911c000 r-xp 00000000 08:05 787272     /usr/lib/xbmc/xbmc.bin
[...]snipped more than 1000 lines like the last one[...]
b7787000-b778b000 rw-p 00000000 00:00 0
b7792000-b7799000 rw-p 00000000 00:00 0
b7799000-b779a000 r-xp 00000000 00:00 0          [vdso]
b779a000-b77ba000 r-xp 00000000 08:05 2491239    /lib/i386-linux-gnu/ld-2.15.so
b77ba000-b77bb000 r--p 0001f000 08:05 2491239    /lib/i386-linux-gnu/ld-2.15.so
b77bb000-b77bc000 rw-p 00020000 08:05 2491239    /lib/i386-linux-gnu/ld-2.15.so
bfca9000-bfcca000 rw-p 00000000 00:00 0          [stack]
Aborted (core dumped)
xbmc_crashlog:
Date: Thu Dec  6 08:22:57 CET 2012
XBMC Options:
Arch: i686
Kernel: Linux 3.2.0-34-generic-pae #53-Ubuntu SMP Thu Nov 15 11:11:12 UTC 2012
Release:
    Description:    Ubuntu 12.04.1 LTS - XBMCbuntu
    Release:    12.04
    Codename:    precise
=====>  Core file: /home/xbmc/core (2012-12-06 08:22:57.683134927 +0100)
[New LWP 1727]
Using host libthread_db library "/lib/i386-linux-gnu/libthread_db.so.1".
Program terminated with signal 6, Aborted.
#0  0xb7799424 in __kernel_vsyscall ()
Thread 1 (Thread 0xb34e8740 (LWP 1727)):
#1  0xb5d021df in raise () from /lib/i386-linux-gnu/libc.so.6
#2  0xb5d05825 in abort () from /lib/i386-linux-gnu/libc.so.6
#3  0xb5d3f39a in ?? () from /lib/i386-linux-gnu/libc.so.6
#4  0xb5d49ee2 in ?? () from /lib/i386-linux-gnu/libc.so.6
#5  0xb61fc60d in snd_config_substitute () from /usr/lib/i386-linux-gnu/libasound.so.2
#6  0xb61fe158 in ?? () from /usr/lib/i386-linux-gnu/libasound.so.2
#7  0xb61fedc9 in snd_config_update_r () from /usr/lib/i386-linux-gnu/libasound.so.2
#8  0xb61ff358 in snd_config_update () from /usr/lib/i386-linux-gnu/libasound.so.2
#9  0x0877be29 in CAESinkALSA::EnumerateDevicesEx(std::vector<CAEDeviceInfo, std::allocator<CAEDeviceInfo> >&) ()
#10 0x087654e1 in CAESinkFactory::EnumerateEx(std::vector<AESinkInfo, std::allocator<AESinkInfo> >&) ()
#11 0x0876b578 in CSoftAE::CSoftAE() ()
#12 0x08763d65 in CAEFactory::LoadEngine(AEEngine) ()
#13 0x08763ed0 in CAEFactory::LoadEngine() ()
#14 0x08bd0dbf in CApplication::Create() ()
#15 0x08c71e6c in XBMC_Run ()
#16 0x082d5366 in main ()
08:22:57 T:3008268096  NOTICE: -----------------------------------------------------------------------
08:22:57 T:3008268096  NOTICE: Starting XBMC (12.0-BETA2 Git:Unknown), Platform: Linux (Ubuntu 12.04.1 LTS - XBMCbuntu, 3.2.0-34-generic-pae i686). Built on Dec  2 2012
08:22:57 T:3008268096  NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
08:22:57 T:3008268096  NOTICE: special://xbmcbin/ is mapped to: /usr/lib/xbmc
08:22:57 T:3008268096  NOTICE: special://masterprofile/ is mapped to: /home/xbmc/.xbmc/userdata
08:22:57 T:3008268096  NOTICE: special://home/ is mapped to: /home/xbmc/.xbmc
08:22:57 T:3008268096  NOTICE: special://temp/ is mapped to: /home/xbmc/.xbmc/temp
08:22:57 T:3008268096  NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
08:22:57 T:3008268096  NOTICE: Local hostname: HTPC
08:22:57 T:3008268096  NOTICE: Log File is located: /home/xbmc/.xbmc/temp/xbmc.log
xbmc.log:
To me it does not look like an error due to a skin, but i would try that if i knew which file to be edited to go back to the default skin.
EDIT: There was a .asoundrc file under /home/xbmc (not /etc) which I deleted, now XBMC is back again.
Yes for future reference purposes, /etc/asound.conf (global config file) and .asoundrc is per user config file they exist (user created or xbmcbuntu creates it) as you found out in difference directories, always have.
Wrong config files can send everything into disarray. specially sound related. XBMCbuntu is probably generating something wrong for AE from the days you needed config files to get your audio in XBMC working.
I guess your problem is fixed then.
uNi
