I'm using a Vista MCE remote which has a launch internet button. It works fine if I'm not in XBMC, but if XBMC is open it no longer works. XBMC intercepts the button press and goes to the first item in whatever list/menu I'm in. I've removed all entries for <browser_home> in the keymap file and still no help.
You'll need to use something like the Advanced Launcher add-on to launch an external application (web browser) while in XBMC. You may then be able to map your remote's "web browser" button to launch your defined Advanced Launcher app (which, in turn, launches the external web browser). Use the forum search function to look for "web browser" and you should find several existing threads on how to do this, either with Advanced Launcher or in some other ways.
