Cool, thank you. Thinking about trying this, but hoping it will be added after Frodo. Don't really like patching things myself. But a question, would it be possible to detect the mode from the movie playing so you don't have to manually change subtitle mode?
I believe it's possible but to do that more code investigation is needed. Also some changes in global settings are needed to turn on/off 3d auto mode. I will try to do that mode but not sure when.
You need to do the same for GUI - patches that only duplicate subtitles are "half solutions" and won't be merged.
pieh is right. He gave to me link elupus patch long time ago. This patch adapting gui to display hsbs/hou, but the playing movie was not good. I've tried to correct it but my knowledge of c++ was very weak
So I decided run 3D hdmi frame-packing on bino. So I modified openelec config files, and wrote simple patch to XBMC for handling switching 3D signal to TV set. You can read on this link:
http://sd-xbmc.org/?q=node/3
ktrz if you know more better c++ like me, and you are interested to include playing 3D files to XBMC let me know.
pieh, could you create patch for xbmc 11? I have old linux, and old libraries of taglib and etc...
I don't get point of creating patch against previous release - this won't be backported and I certainly won't spend time on it. We are in development forum, if you want to help, you need to be able to build latest stuff ...
In any case I got info that it seems to work with few glitches:
1. sometimes left/right views for GUI are getting out of sync and they both display different things
2. missing some details from textures (propably because currently we render half sbs/half tab and squashed elements are missing some "important" pixels)
i have compiled the source from git. The 3D mode is not working when i press the y key.
In the log i found this entry:
ERROR: Keymapping error: no such action '3dmode' defined
When i press the y key i get following:
03:13:39 T:3037587200 DEBUG: Keyboard: scancode: 34, sym: 0079, unicode: 0079, modifier: 0
03:13:39 T:3037587200 DEBUG: OnKey: y (f059) pressed, action is
What wrong whit the compiled Xbmc?
Edit Sorry it was my fault to not clone the git correctly Oo
pieh - check out the rPI stuff - IIRC there is code that detects the 3D-mode from filename and also sends correct commands via HDMI to the TV. Don't have a link at hand - but there is a recent PR improving it IIRC.
jaaps, I have an LG passive tv also. your addons will be very useful. Thanks.
(2013-01-14, 15:11)jaaps Wrote: [ -> ]I really want to thank pieh for his patch. It was the last part I needed to get right for my mediacenter. Thanks!
Since I'm using a passive 3D TV I rip all my 3d blurays to under/over format. I've changed the code a bit for switching between over/under and 2d more easily since I don't use the other 3d formats. See: https://github.com/jaaps/xbmc/commit/f4d...2435808fd5 .
I also made a very simple addon for XBMC that switches 3D to under/over automatically. For that see: https://github.com/jaaps/script.custom.3dmodexbmc
And the last part to make it complete is an addon for XBMC that turns on the 3D on my LG TV with their http-api. See: https://github.com/jaaps/script.custom.3dmodelgtv
I'm just posting this here incase someone has some use for it (although I kinda doubt it) and of course to thank pieh and others for their work!
Edit: I made a mistake in my initial code for TAB action. See https://github.com/jaaps/xbmc/commit/c96...c5a24bf2e3 for fix
I also have a LG TV. How automatic is this? Is it possible to start a 3D movie and not have to assign actions to a button on my remote? But i don't have all my 3D in under/over.
