2012-12-05, 23:36
I am using a Linux Mint distro, just installed it today , and i figured I wanted to use xbmc with it.
So I downloaded xbmc using package manager and I get error , xbmc icon loads and then it shuts down.
andrew@cicero ~ $ xbmc
WARNING: gnome-keyring:: couldn't connect to: /tmp/keyring-9ZFWib/pkcs11: No such file or directory
ALSA lib conf.c:1220parse_def) show is not a compound
ALSA lib conf.c:1686snd_config_load1) _toplevel_:24:26:Unexpected char
ALSA lib conf.c:3406config_file_open) /usr/share/alsa/pulse-alsa.conf may be old or corrupted: consider to remove or fix it
Running DIL (3.22.0) Version
DtsDeviceOpen: Opening HW in mode 0
DtsDeviceOpen: Create File Failed
Fatal error encountered, aborting
Error log at /home/andrew/.xbmc/temp/xbmc.log
Aborted
Crash report available at /home/andrew/xbmc_crashlog-20121205_223449.log
Here is the crashlog: http://pastebin.com/cp2bBvVz
Aborted
