(2014-07-23, 21:40)ronie Wrote: [ -> ] (2014-07-23, 15:57)Ed76 Wrote: [ -> ]for me "airplay" isnt working with CU LRC Lyrics enabled. if i disable CU LRC Lyrics airplay is working fine (gotham 13.1, win 8 x64). is there something i can do or is this a bug?
try disabling these options in the addon settings:
- search for embedded lyrics
- search for local lyrics files
thanks but didnt work. can anyone confirm that there is a bug with airplay?
Wonder if anyone can help me. I can not get lyrics to work using Aeon Nox 5 Minimalistic. I have been searching for a week now trying to find the solution myself. Most results from my search is for older version, (frodo, Nox 4..etc) I have not found anyone having troubles with this skin. I have tried to use Confluence and lyrics are spotty. Sometime they work and then they don't. In Confluence, I can play a song and it will find lyrics but play the same song again, and it won't. I can see by looking in the lryics folder that they are being downloaded. So I am hoping someone here can help.
Gotham 13.1
Culyrics is set as a service.
Here is the log file:
http://xbmclogs.com/show.php?id=253745
Whenever there are multiple lyrics found and I context or right click into the list to select a different lyric file nothing happens when I try to select a choice from the list. Here is the error generated in the log.
PHP Code:
ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.AttributeError'>
Error Contents: 'GUI' object has no attribute 'get_lyrics_from_list'
File "C:\Users\me\AppData\Roaming\XBMC\addons\script.cu.lrclyrics\resources\lib\gui.py", line 450, in onClick
self.get_lyrics_from_list( self.getControl( 120 ).getSelectedItem() )
AttributeError: 'GUI' object has no attribute 'get_lyrics_from_list'
(2014-07-05, 17:53)ronie Wrote: [ -> ] (2014-06-25, 01:03)capfuturo Wrote: [ -> ]@ronie: I can see by looking at the current code (below) that it doesn't consider the scenario in which the file names contain the form %N %A - %T (Track Artist - Title.ext), e.g. '05 Marillion - Montréal.flac' . I just finished retagging my whole music library with Musicbrainz Picard to have this naming convention, which is available in XBMC, and to my surprise I am unable to get .lrc lyrics online, download them and saved them locally.
Would you be so kind Ronie to include this form, so the .lrc lyrics could be found again online? Thank you!
sure, i'll add this.
Awesome. Thank you very much indeed! Jav
I'm still getting this 32006 error code in some .lrc files.
"<result errmsg="Search ID or Code error!" errcode="32006"></result>"
I know I could turn off TTPlayer searching, but would it be possible to not write the .lrc file if it's 110 bytes long, as all the bad ones are exactly that length (at least on a Raspberry Pi). I doubt there's a lot of real lrc files of that length.
(2014-08-10, 02:59)cachirro Wrote: [ -> ]i get script failed
any help?
it works on my android, but on pc i get always that error, immediately after installation or xbmc start.
what can i do?
Is there a way to reposition the panel the lyrics are showing on now? i am using aeon nox on the latest alpha of xbmc and the lyric panel is in the centre, is there an xml i could mess with to move the panel to the top right?
(2014-08-12, 20:50)cachirro Wrote: [ -> ] (2014-08-11, 15:06)ronie Wrote: [ -> ] (2014-08-11, 01:03)cachirro Wrote: [ -> ]it works on my android, but on pc i get always that error, immediately after installation or xbmc start.
what can i do?
please post a Debug Log
uploaded with ID 267067
reinstall this addon:
http://mirrors.xbmc.org/addons/frodo/scr...-2.1.2.zip
restart xbmc and keep your fingers crossed.
addon just updated and now it's gone.. No CU LRC Lyrics addon to be found anywhere.
[edit] It's not to be found in the repo either
[edit2] If anyone is weirding out about their lyrics all the sudden dropping to the default addon skin xml file after an update of the lyrics addon it's because the filename that the addon searches for has changed to "script-cu-lrclyrics-main.xml" and it will no longer recognize the file "script-XBMC_Lyrics-main.xml". It would have been nice to have some kind of heads up about this. Maybe a post on this thread or something. Still don't know why after it updated it completely deleted the addon and it's directory without notice.
(2013-12-09, 20:32)curtis-r Wrote: [ -> ]If someone wants to activate the script with the letter 't' for example, put this under the Visualization section of the keyboard.xml file.
<t>XBMC.RunScript(script.cu.lrclyrics)</t>
I can't seem to find the keyboard.xml file
Hello,
I'm using xbmc 13.2 RC1 with Black Glass Nova skin.
When I play a music file in full screen the lyrics show up with no problems, but the upper and lower info tabs are not showing up when I move the mouse.
As soon as I press left or right arrows on my keyboard, the lyrics disappear and won't come back unless I stop and replay the song. The info tabs show up while the lyrics are gone.
