Ah thanks. For some reason I thought that option would take the filename of the track and slap an .lrc on the end.
I've installed your incremental release with the additional track naming convention. Thanks for that.
I still seem to be having some issues though. This is the debug log:
48 DEBUG: CU LRC Lyrics: failed to get artist and title from filename
21:12:33 T:3988 DEBUG: Previous line repeats 2 times.
21:12:33 T:3988 DEBUG: CTextureCacheJob::GetImageHash - unable to stat url
21:12:33 T:32 DEBUG: CTextureCacheJob::GetImageHash - unable to stat url smb://megatron/music/Files/Everything/Triosphere/[2014] The Heart of the Matter/cdart.png
21:12:33 T:2748 DEBUG: CU LRC Lyrics: failed to get artist and title from filename
21:12:33 T:2748 DEBUG: CU LRC Lyrics: Missing Artist or Song name in ID3 tag for next track
21:12:33 T:4164 NOTICE: [Artist Slideshow] script version 1.8.7 started
21:12:33 T:4164 NOTICE: [Artist Slideshow] debug logging set to false
21:12:33 T:4164 NOTICE: [Artist Slideshow] script stopped
21:12:33 T:4164 INFO: CPythonInvoker(54, C:\Users\mike\AppData\Roaming\Kodi\addons\script.artistslideshow\default.py): script successfully run
21:12:34 T:4164 INFO: Python script stopped
21:12:34 T:4164 DEBUG: Thread LanguageInvoker 4164 terminating
21:12:36 T:4204 DEBUG: ------ Window Deinit (DialogKaiToast.xml) ------
21:12:40 T:4204 DEBUG: Keyboard: scancode: 0x38, sym: 0x0134, unicode: 0x0000, modifier: 0x100
21:12:40 T:4204 DEBUG: CInputManager::OnKey: alt-leftalt (0x4f0d4) pressed, action is
21:12:41 T:4204 DEBUG: CWinEventsWin32::WndProcWindow is active
21:12:41 T:4204 DEBUG: CWinEventsWin32::WndProc: Focus switched to process C:\Windows\explorer.exe
21:12:46 T:4204 DEBUG: CJoystick::Initialize : No Joystick found
21:12:46 T:4204 DEBUG: CWinEventsWin32::WndProcWindow is active
21:12:46 T:4204 DEBUG: ------ Window Init (MusicOSD.xml) ------
21:12:46 T:4204 DEBUG: Keyboard: scancode: 0x38, sym: 0x0134, unicode: 0x0000, modifier: 0x100
21:12:46 T:4204 DEBUG: CInputManager::OnKey: alt-leftalt (0x4f0d4) pressed, action is
21:12:46 T:4204 DEBUG: CWinEventsWin32::WndProc: Focus switched to process C:\Windows\explorer.exe
21:12:46 T:4204 INFO: XCURL:
llLibCurlGlobal::CheckIdle - Closing session to
http://www.msftncsi.com (easy=20D81008, multi=00000000)
21:12:49 T:4204 DEBUG: ------ Window Deinit (MusicOSD.xml) ------
Not sure what's up there.
