those were the days :-)
all it took to write a program was
10 PRINT "HELLO"
20 GOTO 10
and now i'm stuck in python trying to fix a bug i can't reproduce :-(
can you post a
Debug Log (with logging enabled in the addon)?
i tested it with kodi jarvis / jarvis version of cu lrc / confluence skin..
- play a song with lrc lyrics
- next play another song with the lrc lyrics you've posted
but all is fine on my end.
(2016-10-19, 01:01)ronie Wrote: [ -> ]can you post a Debug Log (with logging enabled in the addon)?
Sorry ronie, you're totally right, I have just tested it with confluence and everything was OK. I made my tests in several skins modded for me, so I think I must have some kind of strange bug... I won't stop until I solve it...
Sorry for the time you've lost with this and many thanks for the work you're doing with this addon! It's great!
So now it's time for a CLS command... You know, back then we used them all the time...
This is making me go crazy... I'm unable to find the reason why the lrc lyrics gets stuck sometimes in the first line, so I thought that maybe you could help me...
http://paste.ubuntu.com/23352446/
I'm not in a hurry, take your time, since it's not an important issue.
Manuel try to turn off "search for embedded lyrics" and "genius"in settings for addon.
Some of *.lrc have no time or is just txt file
evan some file have strange end in notpad++ CR LF (\r\n) ,I think that cose isue with reading too.
for me is now good and dont stop in first row in mq6
(2016-10-20, 23:00)Angelinas Wrote: [ -> ]Manuel try to turn off "search for embedded lyrics" and "genius"in settings for addon.
Angelinas, thanks for your testing!
we you guys able to figure something out?
i had a look at the logfile, but it all seems normal.
if the addon finds a local .lrc file, it will not use any scraper at all (genius or any other),
so it's not very likely that setting could cause any issues?
a search for embedded lyrics happens before looking for a local file though.
as far as i know there are no differences between cu lrc for jarvis and krypton in this regard.
(2016-10-21, 11:42)ronie Wrote: [ -> ]we you guys able to figure something out?
I don't have the option to search for embedded files activated. I don't know what can be happening but I do know what works... I'm using the master branch in Jarvis and the problem is gone... I don't know if that can have any other side effect, but it works like a charm and I don't see any error reported in the log... but as always you know better. I don't know if that can give you some clue...
sorry, it only makes it more confusing to me.. guess i fail to follow what you're saying...
is there still a problem or not? :-)
if yes, where/when/how/what...
(2016-10-21, 12:29)ronie Wrote: [ -> ]sorry, it only makes it more confusing to me.. guess i fail to follow what you're saying...
Sorry... I would try to explain it better...
I'm on Jarvis, I don't have Krypton yet.
If I install the version of the script for Jarvis (from addons menu in Kodi) the problem appears. If I download from github the master branch (that I suppose is for Krypton) go to addons folder, delete manually the cu lrc lyrics script folder and put there instead the master/krypton version all is fine.
The main problem is that I'm releasing my mod (for Jarvis) this weekend and therefore the version of the script that people will be using is the one that has those occasional issues with my mod.
Yes,
Where?
in kodi version Krypton ,CU LRC Lyrics version="5.0.8"
When ?
when player start song (lrc dont have file on HD),
How?
Song:
02 - Gangsta Lovin' (feat. Alicia Keys).mp3
Artist:
Alicia Keys
always stay at first row...source is embedded as you see om image (no meter what skin use).And dont save that file in folder.
Why?
I dont know....try yourself and do some test.I just make excample...have more song.
(2016-10-21, 17:04)Angelinas Wrote: [ -> ] (2016-10-21, 12:29)ronie Wrote: [ -> ]sorry, it only makes it more confusing to me.. guess i fail to follow what you're saying...
Yes,
Where?
When ?
How?
Song:
Artist:
Alicia Keys
Why?
thanx for the report, could you please provide a
Debug Log?
(2016-10-21, 12:45)manfeed Wrote: [ -> ] (2016-10-21, 12:29)ronie Wrote: [ -> ]sorry, it only makes it more confusing to me.. guess i fail to follow what you're saying...
hmm...there aren't many differences between the jarvis on krypton versions.
i will backport the remaining changes to jarvis and let you check if that fixes the problem.
...and done :-)
i would appreciate it if you could test the jarvis branch and let me know
