With latest update there is a blank option in the settings dialog:
also now lyrics are saved in the album folder. tnx
(2013-03-05, 09:46)crni Wrote: [ -> ]With latest update there is a blank option in the settings dialog:
thanx, will fix it ;-)
it should read: "Save lyrics to song folder"
hi guys, thanks for this amazing addon, can't live without it!
Question, if i "Save lyrics to song folder",
next time i play the same song, lyrics will be read from that saved file
or it will check on the internet again?
thansk!
(2013-03-08, 23:26)eskro Wrote: [ -> ]Question, if i "Save lyrics to song folder",
if it's a lrc based lyrics file, the addon will use it right away.
but if it's a regular/unsynchrosied lyrics file, the addon will first search online
for lrc based lyrics. if it can't find any, it will use the text file.
Hello there, fantastic work to all of you involved in this!
Would it be possible to add an option so we can chose the colour of the highlighted text when displaying LRC Lyrics? I'd be very pleased if I could match it to the default light blue that is set for the album year, track number for instance. Others may prefer a different colour to match their specific set-up.
Best, CF
(2013-03-11, 02:09)capfuturo Wrote: [ -> ]Hello there, fantastic work to all of you involved in this!
Best, CF
nope, that's up to the skin you're using.
they'll probably match it to whatever colour they're using in the rest of the skin.
Thanks Ronie for your dedication and prompt reply! CF
Well, i've got a little problem with culrclyrics. It works perfectly when downloading lyrics fom internet, but it shows nothing with embedded lyrics. Lots of my MP3 were tagged using the Lyricator plugin on MediaMonkey4, and culrclyrics seems not to read them, the screen remain empty.
(2013-03-15, 15:52)Araldwenn Wrote: [ -> ]Well, i've got a little problem with culrclyrics. It works perfectly when downloading lyrics fom internet, but it shows nothing with embedded lyrics. Lots of my MP3 were tagged using the Lyricator plugin on MediaMonkey4, and culrclyrics seems not to read them, the screen remain empty.
could you provide one mp3 so we can test?
feel free to PM a download link or something...
i agree, it seems there is an issue with lyrics not showing up.
i have to de-select//un-tick lirucs from file in the options and after that,
lyrics show up because they r then downloaded from minilyrcs.com
but if i re-select/re-tick the lyrics from file option,
and replay the same song again,
lyrics wont show up.
I've just PM you an MP3 file so you can test it.
It as unsynced lyrics embedded in it.
If you prefer an other type of music, no prob, I've got an eclectic library ;P
(2013-03-16, 00:10)Araldwenn Wrote: [ -> ]I've just PM you an MP3 file so you can test it.
thanx! will have a look.
(2013-03-16, 00:11)ronie Wrote: [ -> ] (2013-03-16, 00:10)Araldwenn Wrote: [ -> ]I've just PM you an MP3 file so you can test it.
@taxigps:
the txxx tag contains text based lyrics
but the addon assumes they are lrc based.
i'll forward the testfile to you.
(2013-03-16, 00:40)ronie Wrote: [ -> ] (2013-03-16, 00:11)ronie Wrote: [ -> ] (2013-03-16, 00:10)Araldwenn Wrote: [ -> ]I've just PM you an MP3 file so you can test it.
@taxigps:
TXXX tag is user defined text area. So some program use to store lrc lyrics, and some store txt lyrics. I'll try to support both.
