2012-12-06, 21:34
Hi all ... please note that I'm generally new to XBMC ... but pretty decent with software/hardware in general ...
I'll be building a new HTPC ... and was considering using it for live tv too ... I'm currently testing the software on my desktop pc (i5 quad, 8gb, ATI-6950 ... if relevant HTPC will not be as powerful!!) - and am using a Dreambox DM800 as my TV source.
I installed xbmc frodo b2, installed the vuplus addon from here ... it all worked first time - getting channel epg takes ages ... but i might try to disable that or something ...
The actual issue I'm having is channel zap time - best case scenario it takes 5s .... most of the times between 10 and 15s !? Is this normal? Hope not.
Any help guys? Should I wait for final release of frodo, and a better vuplus plugin (it does say it's not stable mind you!)?
Cheers all!
Edit: Any way of selecting the default audio stream globally?
Cheers all!
