Full Version: same muxid - No services
Hello all,
I'm using the latest tvheadend (3.2.18) and I have a problem finding all services in my area. Unfortunately it doesn't exist in the table of tvheadend (Thessaloniki/Greece)
The problem as I understand it is that a few multiplexes want to use the same muxid. So when I add them manually the first one added gets to discover its services, while the others rest with no muxid (and no services)
There are 3 muxes that want muxid 1 and 2 for muxid 2
In the past I had edited the source code to add gr_Thessaloniki and compiled, but since great things are happening with tvheadend nowadays, I don't want to miss them and I don't even remember what I changed.
On a side note, w_scan reports "Info: NIT(actual) filter timeout" when scanning those frequencies, although tvheadend finds services if they are added first
Finally, I had read in the lonely coder forum that someone changed the transportstreamid to something else and it worked. In my case it doesn't
Thank you
Edit: w_scan found everything
NET;ERT:490000:I999B8C999D999M999T999G999Y0:T:27500:138:650:576:0:10:0:0:0
ERA.NET;ERT:490000:I999B8C999D999M999T999G999Y0:T:27500:0:652:0:0:11:0:0:0
ERA 2;ERT:490000:I999B8C999D999M999T999G999Y0:T:27500:0:653:0:0:12:0:0:0
ET1;ERT:490000:I999B8C999D999M999T999G999Y0:T:27500:139:660,662=gre:577:0:20:0:0:0
ERA 3;ERT:490000:I999B8C999D999M999T999G999Y0:T:27500:0:661:0:0:21:0:0:0
ET3;ERT:490000:I999B8C999D999M999T999G999Y0:T:27500:140:670:578:0:30:0:0:0
ERA Sport;ERT:490000:I999B8C999D999M999T999G999Y0:T:27500:0:671:0:0:31:0:0:0
ERT HD;ERT:490000:I999B8C999D999M999T999G999Y0:T:27500:141:680:0:0:40:0:0:0
KOSMOS;ERT:490000:I999B8C999D999M999T999G999Y0:T:27500:0:681:0:0:41:0:0:0
ALPHA;(null):506000:I999B8C999D999M999T999G999Y0:T:27500:1150:1151:1152:0:100:0:0:0
ALTER;(null):506000:I999B8C999D999M999T999G999Y0:T:27500:1250:1251:1252:0:200:0:0:0
ANT1;(null):506000:I999B8C999D999M999T999G999Y0:T:27500:1350:1351:1352:0:300:0:0:0
m.tv;(null):506000:I999B8C999D999M999T999G999Y0:T:27500:1450:1451:1452:0:400:0:0:0
MEGA;(null):538000:I999B8C999D999M999T999G999Y0:T:27500:1550:1551:1552:0:500:0:0:0
SKAI;(null):538000:I999B8C999D999M999T999G999Y0:T:27500:1650:1651:1652:0:600:0:0:0
STAR;(null):538000:I999B8C999D999M999T999G999Y0:T:27500:1750:1751:1752:0:700:0:0:0
...;(null):538000:I999B8C999D999M999T999G999Y0:T:27500:1850:1851:0:0:800:0:0:0
NICKELODEON +;PERTHO:554000:I999B8C999D999M999T999G999Y0:T:27500:102+104:103:0:0:1:0:0:0
EGNATIA;PERTHO:554000:I999B8C999D999M999T999G999Y0:T:27500:112+114:113:0:0:2:0:0:0
EUROPE ONE ;PERTHO:554000:I999B8C999D999M999T999G999Y0:T:27500:122+124:123:0:0:3:0:0:0
DION;PERTHO:554000:I999B8C999D999M999T999G999Y0:T:27500:132+134:133:0:0:4:0:0:0
novacinema1;NetMed:674000:I999B8C999D999M999T999G999Y0:T:27500:42:41:0:604:351:0:0:0
novasports1-Disney XD;NetMed:674000:I999B8C999D999M999T999G999Y0:T:27500:39:38,46=gre,47=CHB:0:604:352:0:0:0
Euro News;NetMed:674000:I999B8C999D999M999T999G999Y0:T:27500:36:35,75=eng:0:0:353:0:0:0
TV5 Europe;NetMed:674000:I999B8C999D999M999T999G999Y0:T:27500:49:48:51:0:354:0:0:0
4E;DBS:706000:I999B8C999D999M999T999G999Y0:T:27500:1151:1152:0:0:1:0:0:0
EURO;DBS       :706000:I999B8C999D999M999T999G999Y0:T:27500:1161+1163:1162:0:0:2:0:0:0
GNOMI;DBS:706000:I999B8C999D999M999T999G999Y0:T:27500:1171+1173:1172:0:0:3:0:0:0
TV100;DBS        :706000:I999B8C999D999M999T999G999Y0:T:27500:1181+1183:1182:0:0:4:0:0:0
VOULI;ERT:754000:I999B8C999D999M999T999G999Y0:T:27500:128:650:0:0:1:0:0:0
BBC World News;ERT:754000:I999B8C999D999M999T999G999Y0:T:27500:129:660:0:0:2:0:0:0
Deutsche Welle;ERT:754000:I999B8C999D999M999T999G999Y0:T:27500:130:670:0:0:3:0:0:0
PIK;ERT:754000:I999B8C999D999M999T999G999Y0:T:27500:131:680:579:0:4:0:0:0
APT;(null):778000:I999B8C999D999M999T999G999Y0:T:27500:1002:1003:0:0:1:0:0:0
XTV;(null):778000:I999B8C999D999M999T999G999Y0:T:27500:2002:2003:0:0:2:0:0:0
9;(null):778000:I999B8C999D999M999T999G999Y0:T:27500:3002:3003:0:0:3:0:0:0
TIME;(null):778000:I999B8C999D999M999T999G999Y0:T:27500:4002:4003:0:0:4:0:0:0
arisp@tsunx:~$ sudo service tvheadend start
tvheadend start/running, process 3360
arisp@tsunx:~$ more channels2.conf
I had 2 muxes that wanted the same ID, fortunately I only wanted one of them so turned off auto discover muxes and removed the one i did not want and the remaining one started working...
There are two major providers here, each with two muxes. Unfortunately they apparently don't like each other and I can't really choose between them Smile
