Full Version: New to XBMC / Ideas and Questions
Hello,
First I would like to say I have just started using XBMC on my Media Center PC, and I freaking love it! I read around to find the best skin for my needs and it happened to be Transparency. I have tweaked it within the user interface as far as it will go, and have searched through the add-ons list but I simply cannot find the two features that would be really nice to have.
The first feature would be a vertical RSS feed that is right justified on the Home screen between the Weather widget and the newly added widget.
The other feature is something like the screensaver, but on the Home screen as well. It would display all of my currently added movies FanArt on the background of the Home screen. I think it would look better than a static wallpaper. Think of it something like Windows 7's new slideshow wallpaper feature.
Thank you,
- NOX
the first one is not possible.
the second one can be done:
settings > skin settings > backgrounds > home - movies > multi image
and select a folder containing all you movie fanart images.
you can use the artwork organizer addon to create such a folder.
