2012-12-09, 16:49
Hi There,
I am not sure whether it is a bug but...
I currently switched to XBMC Frodo Beta 3 from a Frodo Nightly. I am using DVB Viewer as PVR Backend. With the Nightly installed, I had exactly the same setup and I was able to install Channel Logos for PVR in XBMC settings. Now with Beta 3 I want to use exactly the same logos but when I give the path to the logo folder in XBMC settings and then say "search for missing logos" nothing happen. XBMC says it finalized the search but it doesn't show the logos in the PVR. Are there any changes between nightly and Beta3 as far as handling the logos is concerned...?
futuro
futuro
