XBMCbuntu 12
Hey guys, I just did a format and fresh install of XBMCbuntu using from the xbmcbuntu-12_xvba-fglrx_legacy.iso that I downloaded. Problem is that I went to start setting some things up by logging into the XBMCbuntu machine via Putty/SSH, which I do all of the time and was working fine before reformatting, and I get this error in Putty
Quote:"Network error: Software caused connection abort"
What the heck? I do have an onboard LAN card which is disabled in BIOS and I am using a PCI Ethernet adapter to connect wired. It is the same setup I had before reformatting and worked just fine. So I have no idea what is going on. I can SSH into my NAS just fine using Putty, but the new install is blocking this for some reason. Any help or suggestions would be greatly appreciated
To clarify, I can view files on the xbmcbuntu machine from my windows pc. I can also ping my xbmcbuntu machine with response.
@pumkinut: It is. I was an idiot. All I had to do was delete the keys on the machines I was using to login with ssh and it solved the problem. Thanks for the suggestion.
I'm having the same problem as OP, but I'm unable to resolve it so far.
XBMCbuntu 12. I'm able to see the network shares (pictures, music, ...) via Windows 7 client. However I can not SSH via putty. I tried deleting all Putty settings and keys from the registry in Win7. (putty -cleanup). I removed/reinstalled putty. I still get the same "Network error: Software caused connection abort".
Any help appreciated.
1. Open the registry (regedit)
2. Go to HKEY_CURRENT_USER\Software\SimonTatham\PuTTY\SshHostKeys
There you should see Putty’s cache of host keys.
The ‘name’ column tells you which key is for which server.
For example, it will have the format of <something>@<port>:<host> [
[email protected]]
3. Delete the rows that you need and profit.
http://www.chiark.greenend.org.uk/~sgtat...aq-cleanup
putty -cleanup is not gonna do it is it? <- not a question.
uNi
(2013-02-02, 17:12)uNiversal Wrote: [ -> ]HKEY_CURRENT_USER\Software\SimonTatham\PuTTY\SshHostKeys
Thanks for the reply. I tried this as well. I deleted everything \SimonTatham and below before uninstalling/reinstalling. I'm still getting the same error.
At this point I'm pretty sure it's a SSH key authentication problem. I've tried from 2 different systems. Looking at the logs I see things like:
Failed to read 1st key exchange packet
and on another system
Outgoing packet #0x0, type 20 / 0x14 (SSH2_MSG_KEXINIT)....[then what I suspect is a key]
then: Event Log: Network error: Software caused connection abort
I think I need to tell XBMCbuntu to allow my clients, but I'm unsure how to do so.
I had the same issue, which was caused by incorrectly generated SSH keys (during first boot). Check this by opening a terminal and going into the /etc/ssh directory. You will see a bunch of files, 6 of them looking like 'ssh_host_###_key'. If these are 0 bytes in size, you are affected by this as well. Follow these steps to fix the issue:
First, remove the old keys:
rm /etc/ssh/ssh_host_*_key*
Now generate new ones. The command will ask you to set a passphrase or press enter to continue.
Do not set a passphrase!
ssh-keygen -t dsa -f /etc/ssh/ssh_host_dsa_key
ssh-keygen -t rsa -f /etc/ssh/ssh_host_rsa_key
ssh-keygen -t ecdsa -f /etc/ssh_host_ecdsa_key
Restart your SSH service (or reboot). You can now log in again.
(2013-03-03, 18:16)bobfw Wrote: [ -> ]I had the same issue, which was caused by incorrectly generated SSH keys (during first boot). Check this by opening a terminal and going into the /etc/ssh directory. You will see a bunch of files, 6 of them looking like 'ssh_host_###_key'. If these are 0 bytes in size, you are affected by this as well. Follow these steps to fix the issue:
Now generate new ones. The command will ask you to set a passphrase or press enter to continue. Do not set a passphrase!
Couldn't SSH into my fresh XBMCbuntu installation. This fixed my "connection refused" issues.
(2013-09-01, 18:49)weimeanz Wrote: [ -> ] (2013-03-03, 18:16)bobfw Wrote: [ -> ]I had the same issue, which was caused by incorrectly generated SSH keys (during first boot). Check this by opening a terminal and going into the /etc/ssh directory. You will see a bunch of files, 6 of them looking like 'ssh_host_###_key'. If these are 0 bytes in size, you are affected by this as well. Follow these steps to fix the issue:
Thank you for mentioning this; my connection error didn't have the exact same cause as yours but restarting the ssh service did get me on the right track. I needed to reassign permissions to the
ssh/ directory to make the server not ignore the keys (which was the problem).
chmod 600 -R /etc/ssh
After restarting ssh with those permissions in place I had no problem connecting.
