a small problem...
when I play a movie and the movie is end then the normal view will open.. okay. shure
Now the animation of the focus not start. The poster how are focus have a animtion zoom 120% but it don´t start after playback.
In Confluence is it the same. It look it will not focused
Same thing happens when you select a song to play - the list has focus but the focus animation doesn't kick in.
Bug fix for Frodo?
I don´t check it on Eden hmm. is there the same?
Quickest way to test -
Change line 263 of ViewsMusicLibrary.xml in Confluence to <visible>Container.Content(songs)</visible> then enter an album and change the view type to Fanart.
Select any song.
EDIT: Eden and Frodo tested.
(2012-12-11, 11:06)Hitcher Wrote: [ -> ]Quickest way to test -
Select any song.
I till at work.
the same problem, no focus animation?
reproduced and found issue, shouldn't take long to fix it
Thanks pieh.
Did this miss out on being added to RC1?
(2012-12-12, 20:10)Hitcher Wrote: [ -> ]Did this miss out on being added to RC1?
Yes
Then it's not 'not working', thanks.
Try the next nightly
Confirmed working in RC2, thanks.
Same behaviour when opening a large folder and the progress dialog kicks in. After it's finished control isn't returned to the list.
