2012-12-13, 01:25
Since I switched to Frodo I've been having problems related with DTS.
I am running RC 1 currently, and this is what happening:
Playing this video file, results in no audio coming in from the TV or my Home Theather:
Playing this second video file, results in the voices from the movie (I guess the center channel) missing in most of the movie (unable to hear through the center channel, or through the TV speakeres)
First File, I just edit audio settings, switch from Output HDMI to Output Analog to hear again. (from both TV Speakers and Home Theater)
Second File, I disable DTS capable receiver to hear again (from both TV Speakers and Home Theater)
My output settings are pretty standard. Both Audio Outputs set to HDMI, Dolby Digital receiver checked, DTS receiver checked, etc.
If I go back to Eden, both files work great with same Output settings, so I guess it's related with to Audio Engine
Anybody else experiencing similar symptoms?
Thank you.
Here's the media info of the second file:
General
Unique ID : 233799533577222270896587075794684413650 (0xAFE426FB2AEAE136AC6373A3972506D2)
Complete name : /Volumes/Storage/Star Trek Tng/Star Trek Tng - S02E18.mkv
Format : Matroska
Format version : Version 2
File size : 2.18 GiB
Duration : 45mn 25s
Overall bit rate : 6 875 Kbps
Encoded date : UTC 2012-11-22 03:34:51
Writing application : mkvmerge v5.8.0 ('No Sleep / Pillow') built on Sep 2 2012 15:37:04
Writing library : libebml v1.2.3 + libmatroska v1.3.0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 45mn 25s
Bit rate : 5 366 Kbps
Width : 976 pixels
Height : 720 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.318
Stream size : 1.66 GiB (76%)
Title : X264
Writing library : x264 core 129 r2230 1cffe9f
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=5366 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Audio
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Duration : 45mn 25s
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 491 MiB (22%)
Title : DTS
Language : English
Default : Yes
Forced : No
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Title : English
Language : English
Default : No
Forced : No
Thank you.
General
Unique ID : 234187448563785356968351872157398727245 (0xB02EDCAAA596A1FDACB441D255B9FA4D)
Complete name : /Volumes/drobo/mkv/Done/Resident Evil Retribution (2012).mkv
Format : Matroska
File size : 10.0 GiB
Duration : 1h 35mn
Overall bit rate : 15.0 Mbps
Encoded date : UTC 2012-12-08 06:46:01
Writing application : mkvmerge v5.5.0 ('Healer') built on Apr 6 2012 21:43:24
Video
Format : AVC
Duration : 1h 35mn
Bit rate : 13.5 Mbps
Width : 1 920 pixels
Height : 800 pixels
Display aspect ratio : 2.40:1
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.367
Stream size : 8.83 GiB (88%)
Title : Resident.Evil.Retribution.2012.1080p.BluRay.DTS.x264-HDMaNiAcS
Encoding settings : cabac=1 / ref=5 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=tesa / subme=11 / psy=1 / psy_rd=0.80:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc=2pass / mbtree=0 / bitrate=13500 / ratetol=1.0 / qcomp=0.65 / qpmin=10 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=2:0.55
Language : English
Default : Yes
Forced : No
Audio
Format : DTS
Codec ID : A_DTS
Duration : 1h 35mn
Bit depth : 24 bits
Stream size : 1.01 GiB (10%)
Language : English
Default : Yes
Forced : No
Text #1
Format : PGS
Codec ID : S_HDMV/PGS
Codec ID/Info : The same subtitle format used on BDs/HD-DVDs
Language : English
Default : Yes
Forced : No
Text #2
Format : PGS
Language : Greek
Default : No
Forced : No
Text #3
Format : PGS
Language : Bulgarian
Default : No
Forced : No
Text #4
Format : UTF-8
Language : English
Default : No
Forced : No
Text #5
Format : UTF-8
Language : Greek
Default : No
Forced : No
Text #6
Format : UTF-8
Language : Czech
Default : No
Forced : No
Text #7
Format : UTF-8
Language : Dutch
Default : No
Forced : No
Text #8
Format : UTF-8
Language : Finnish
Default : No
Forced : No
Text #9
Format : UTF-8
Language : Polish
Default : No
Forced : No
Text #10
Format : UTF-8
Language : Spanish
Default : No
Forced : No
Text #11
Format : UTF-8
Language : Swedish
Default : No
Forced : No
Menu
00:00:00.000 : en:00:00:00.000
00:07:43.046 : en:00:07:43.046
00:14:32.538 : en:00:14:32.538
00:21:38.839 : en:00:21:38.839
00:25:39.329 : en:00:25:39.329
00:29:31.186 : en:00:29:31.186
00:34:16.846 : en:00:34:16.846
00:39:14.769 : en:00:39:14.769
00:45:29.435 : en:00:45:29.435
00:50:27.441 : en:00:50:27.441
00:54:42.070 : en:00:54:42.070
01:00:14.861 : en:01:00:14.861
01:05:38.476 : en:01:05:38.476
01:11:22.904 : en:01:11:22.904
01:16:15.571 : en:01:16:15.571
01:21:29.384 : en:01:21:29.384
