2005-09-09, 16:38
i have problem playing some new dvd-r releases on xbmc cvs 050906 when streaming the rar files with smb from my fileserver (debian).
when i try to start the movie the popup window says it found dvd media, then the screen go black for 1-2 sec and returns to filebrowser.
here are xbmc.log file when trying two different dvds:
Quote:09-09-2005 16:20:47 info mplayer play:rar://z:\temp\,1,,smb://xbox:[email protected]/dvdr-pal/the.deal.2005.nordic.pal.dvdr-bbdvdr/the.deal.complete-bbdvdr.rar,\the.deal.complete-bbdvdr.img cachesize:4096
09-09-2005 16:20:47 debug msg: set audio functions called
09-09-2005 16:20:47 debug msg: done
09-09-2005 16:20:47 info dvddevice: rar://z:\temp\,1,,smb://xbox:[email protected]/dvdr-pal/the.deal.2005.nordic.pal.dvdr-bbdvdr/the.deal.complete-bbdvdr.rar,\the.deal.complete-bbdvdr.img
09-09-2005 16:20:47 info flipping bi-directional subtitles disabled
09-09-2005 16:20:47 debug msg:mplayer_init()
09-09-2005 16:20:47 debug msg:enable mplayer osd
09-09-2005 16:20:47 debug msg:mplayer dev-cvs-050906-20:54 (c) 2000-2004 mplayer team
09-09-2005 16:20:47 debug msg:cpu: intel celeron 2/pentium iii coppermine,geyserville
09-09-2005 16:20:47 debug msg:(family: 6, stepping: 10)
09-09-2005 16:20:47 debug msg:detected cache-line size is 32 bytes
09-09-2005 16:20:47 debug msg:cpuflags: mmx: 1 mmx2: 1 3dnow: 0 3dnow2: 0 sse: 0 sse2: 0
09-09-2005 16:20:47 debug msg:compiled for x86 cpu with extensions:
09-09-2005 16:20:47 debug msg: mmx
09-09-2005 16:20:47 debug msg: mmx2
09-09-2005 16:20:47 debug msg: sse
09-09-2005 16:20:47 debug msg:creating config file: q:\system\players\mplayer\config
09-09-2005 16:20:47 debug msg:88 audio & 199 video codecs
09-09-2005 16:20:47 debug msg:mplayer_open_file(dvd://)
09-09-2005 16:20:47 info stating file dvd://.conf
09-09-2005 16:20:47 info stating file q:\system\players\mplayer\.conf
09-09-2005 16:20:47 debug msg:playing dvd://.
09-09-2005 16:20:47 debug msg:do not search for subs
09-09-2005 16:20:47 info msg:libdvdcss debug: opening target `rar://z:/temp/,1,,smb://xbox:[email protected]/dvdr-pal/the.deal.2005.nordic.pal.dvdr-bbdvdr/the.deal.complete-bbdvdr.rar,/the.deal.complete-bbdvdr.img'
09-09-2005 16:20:47 info msg:libdvdcss debug: using libc for access
09-09-2005 16:20:48 info msg:libdvdcss debug: using css key cache dir: q:\system\players\mplayer\dvdkeys//the_deal#2005090806401600/
09-09-2005 16:20:48 debug msg:reading disc structure, please wait...
09-09-2005 16:20:48 debug msg:there are 12 titles on this dvd.
09-09-2005 16:20:48 debug msg:there are 1 chapters in this dvd title.
09-09-2005 16:20:49 debug msg:there are 1 angles in this dvd title.
09-09-2005 16:20:49 info loading skin file: dialogprogress.xml
09-09-2005 16:20:51 debug msg:dvd successfully opened.
cache fill: 0.00% (0 bytes)
09-09-2005 16:20:51 info msg:libdvdcss debug: cracking title key
09-09-2005 16:20:52 debug msg:
09-09-2005 16:20:53 debug msg:
09-09-2005 16:20:53 info msg:libdvdcss debug: end of title reached
09-09-2005 16:20:53 info msg:libdvdcss debug: 0 of 0 attempts successful, 0 of 2000 blocks scrambled
09-09-2005 16:20:53 info msg:libdvdcss debug: file was unscrambled
09-09-2005 16:20:53 info msg:libdvdcss debug: title key is 00:00:00:00:00
09-09-2005 16:20:53 info msg:libdvdcss debug: unencrypted title
cache fill: 0.20% (8192 bytes)
09-09-2005 16:20:53 debug msg:stream_enable_cache() eof detected
09-09-2005 16:20:53 debug msg:mpeg-ps file format detected.
09-09-2005 16:20:53 debug msg:mpeg: no audio stream found -> no sound.
09-09-2005 16:20:53 debug msg:video: mpeg2 720x576 (aspect 3) 25.000 fps 8000.0 kbps (1000.0 kbyte/s)
09-09-2005 16:20:53 debug msg:global subsize: 4 - vobsub: -1, demux: 0, subs: -1
09-09-2005 16:20:53 debug msg:global subpos : 0
09-09-2005 16:20:53 debug msg:==========================================================================
09-09-2005 16:20:53 debug msg:opening video decoder: [mpegpes] mpeg 1/2 video passthrough
09-09-2005 16:20:53 debug msg:vdec: vo config request - 720 x 576 (preferred csp: mpeg pes)
09-09-2005 16:20:53 debug msg:could not find matching colorspace - retrying with -vf scale...
09-09-2005 16:20:54 debug msg:opening video filter: [scale]
09-09-2005 16:20:54 debug msg:the selected video_out device is incompatible with this codec.
09-09-2005 16:20:54 debug msg:vdecoder init failed :(
09-09-2005 16:20:54 debug msg:opening video decoder: [libmpeg2] mpeg 1/2 video decoder libmpeg2-v0.4.0b
09-09-2005 16:20:54 debug msg:selected video codec: [mpeg12] vfm:libmpeg2 (mpeg-1 or 2 (libmpeg2))
09-09-2005 16:20:54 debug msg:==========================================================================
09-09-2005 16:20:54 debug msg:audio: no sound
09-09-2005 16:20:54 debug msg:starting playback...
09-09-2005 16:20:54 debug msg:mplayer_open_file(dvd://) done 1.0000
09-09-2005 16:20:56 info activating window id: 12005
09-09-2005 16:20:56 debug playback has started
09-09-2005 16:20:56 info loading skin file: videofullscreen.xml
09-09-2005 16:20:56 notice start led control
09-09-2005 16:20:56 notice dim lcd on playback
09-09-2005 16:20:56 info loading skin file: videoosd.xml
09-09-2005 16:20:56 info loading skin file: videoosdsettings.xml
09-09-2005 16:20:56 debug cguiinfomanager::setcurrentmovie(rar://z:\temp\,1,,smb://xbox:[email protected]/dvdr-pal/the.deal.2005.nordic.pal.dvdr-bbdvdr/the.deal.complete-bbdvdr.rar,\the.deal.complete-bbdvdr.img)
09-09-2005 16:20:56 debug msg:vdec: vo config request - 720 x 576 (preferred csp: planar yv12)
09-09-2005 16:20:56 debug msg:vdec: using planar yv12 as output csp (no 0)
09-09-2005 16:20:56 debug msg:movie-aspect is 1.78:1 - prescaling to correct movie aspect.
09-09-2005 16:20:56 debug msg:vo: [directx] 720x576 => 1024x576 planar yv12
09-09-2005 16:20:56 info created yuv texture
09-09-2005 16:20:56 debug created yv12 texture 0
09-09-2005 16:20:56 debug msg:ffrw:normal play
09-09-2005 16:20:56 debug msg: mplayer_close_file()
09-09-2005 16:20:56 debug msg: uninit_player
09-09-2005 16:20:56 debug deleted yv12 texture (0)
09-09-2005 16:20:56 debug deleted yuv video texture
09-09-2005 16:20:56 debug msg: uninit_player - done
09-09-2005 16:20:56 debug freeing fs segment @ 0x7a78f0
09-09-2005 16:20:56 debug playback has finished
09-09-2005 16:20:56 debug setting resolution 6
09-09-2005 16:20:56 debug we set resolution 6
09-09-2005 16:20:56 info loading skin file: myvideo.xml
09-09-2005 16:21:11 info mplayer play:rar://z:\temp\,1,,smb://xbox:[email protected]/dvdr-pal/national.lampoons.gold.diggers.2003.nordic.pal.dvdr-dfg/dfg-nlgd.rar,\dfg-nlgd.img cachesize:4096
09-09-2005 16:21:11 debug initializing fs_seg..
09-09-2005 16:21:11 debug fs segment @ 0x968010
09-09-2005 16:21:11 debug msg: set audio functions called
09-09-2005 16:21:11 debug msg: done
09-09-2005 16:21:11 info dvddevice: rar://z:\temp\,1,,smb://xbox:[email protected]/dvdr-pal/national.lampoons.gold.diggers.2003.nordic.pal.dvdr-dfg/dfg-nlgd.rar,\dfg-nlgd.img
09-09-2005 16:21:11 info flipping bi-directional subtitles disabled
09-09-2005 16:21:11 debug msg:mplayer_init()
09-09-2005 16:21:11 debug msg:enable mplayer osd
09-09-2005 16:21:11 debug msg:mplayer dev-cvs-050906-20:54 (c) 2000-2004 mplayer team
09-09-2005 16:21:11 debug msg:cpu: intel celeron 2/pentium iii coppermine,geyserville
09-09-2005 16:21:11 debug msg:(family: 6, stepping: 10)
09-09-2005 16:21:11 debug msg:detected cache-line size is 32 bytes
09-09-2005 16:21:11 debug msg:cpuflags: mmx: 1 mmx2: 1 3dnow: 0 3dnow2: 0 sse: 0 sse2: 0
09-09-2005 16:21:11 debug msg:compiled for x86 cpu with extensions:
09-09-2005 16:21:11 debug msg: mmx
09-09-2005 16:21:11 debug msg: mmx2
09-09-2005 16:21:11 debug msg: sse
09-09-2005 16:21:11 debug msg:creating config file: q:\system\players\mplayer\config
09-09-2005 16:21:11 debug msg:88 audio & 199 video codecs
09-09-2005 16:21:11 debug msg:mplayer_open_file(dvd://)
09-09-2005 16:21:11 info stating file dvd://.conf
09-09-2005 16:21:11 info stating file q:\system\players\mplayer\.conf
09-09-2005 16:21:11 debug msg:playing dvd://.
09-09-2005 16:21:11 debug msg:do not search for subs
09-09-2005 16:21:11 info msg:libdvdcss debug: opening target `rar://z:/temp/,1,,smb://xbox:[email protected]/dvdr-pal/national.lampoons.gold.diggers.2003.nordic.pal.dvdr-dfg/dfg-nlgd.rar,/dfg-nlgd.img'
09-09-2005 16:21:11 info msg:libdvdcss debug: using libc for access
09-09-2005 16:21:11 info msg:libdvdcss debug: using css key cache dir: q:\system\players\mplayer\dvdkeys//gold__diggers#2005062916462800/
09-09-2005 16:21:11 debug msg:reading disc structure, please wait...
09-09-2005 16:21:12 debug msg:there are 10 titles on this dvd.
09-09-2005 16:21:12 debug msg:there are 1 chapters in this dvd title.
09-09-2005 16:21:12 debug msg:there are 1 angles in this dvd title.
09-09-2005 16:21:13 info loading skin file: dialogprogress.xml
09-09-2005 16:21:15 debug msg:dvd successfully opened.
09-09-2005 16:21:15 info msg:libdvdcss debug: cracking title key
09-09-2005 16:21:16 debug msg:
09-09-2005 16:21:17 debug msg:
09-09-2005 16:21:17 info msg:libdvdcss debug: end of title reached
09-09-2005 16:21:17 info msg:libdvdcss debug: 0 of 0 attempts successful, 0 of 2000 blocks scrambled
09-09-2005 16:21:17 info msg:libdvdcss debug: file was unscrambled
09-09-2005 16:21:17 info msg:libdvdcss debug: title key is 00:00:00:00:00
09-09-2005 16:21:17 info msg:libdvdcss debug: unencrypted title
09-09-2005 16:21:17 debug msg:stream_enable_cache() eof detected
09-09-2005 16:21:17 debug msg:mpeg-ps file format detected.
09-09-2005 16:21:17 debug msg:mpeg: no audio stream found -> no sound.
09-09-2005 16:21:17 debug msg:video: mpeg2 720x576 (aspect 3) 25.000 fps 8000.0 kbps (1000.0 kbyte/s)
09-09-2005 16:21:17 debug msg:global subsize: 4 - vobsub: -1, demux: 0, subs: -1
09-09-2005 16:21:17 debug msg:global subpos : 0
09-09-2005 16:21:17 debug msg:==========================================================================
09-09-2005 16:21:17 debug msg:opening video decoder: [mpegpes] mpeg 1/2 video passthrough
09-09-2005 16:21:17 debug msg:vdec: vo config request - 720 x 576 (preferred csp: mpeg pes)
09-09-2005 16:21:17 debug msg:could not find matching colorspace - retrying with -vf scale...
09-09-2005 16:21:17 debug msg:opening video filter: [scale]
09-09-2005 16:21:17 debug msg:the selected video_out device is incompatible with this codec.
09-09-2005 16:21:17 debug msg:vdecoder init failed :(
09-09-2005 16:21:17 debug msg:opening video decoder: [libmpeg2] mpeg 1/2 video decoder libmpeg2-v0.4.0b
09-09-2005 16:21:17 debug msg:selected video codec: [mpeg12] vfm:libmpeg2 (mpeg-1 or 2 (libmpeg2))
09-09-2005 16:21:17 debug msg:audio: no sound
09-09-2005 16:21:17 debug msg:starting playback...
09-09-2005 16:21:17 debug msg:mplayer_open_file(dvd://) done 1.0000
09-09-2005 16:21:19 info activating window id: 12005
09-09-2005 16:21:19 debug playback has started
09-09-2005 16:21:19 info loading skin file: videofullscreen.xml
09-09-2005 16:21:19 notice start led control
09-09-2005 16:21:19 notice dim lcd on playback
09-09-2005 16:21:19 debug msg:vdec: vo config request - 720 x 576 (preferred csp: planar yv12)
09-09-2005 16:21:19 debug msg:vdec: using planar yv12 as output csp (no 0)
09-09-2005 16:21:19 debug msg:movie-aspect is 1.78:1 - prescaling to correct movie aspect.
09-09-2005 16:21:19 debug msg:vo: [directx] 720x576 => 1024x576 planar yv12
09-09-2005 16:21:19 info created yuv texture
09-09-2005 16:21:19 debug created yv12 texture 0
09-09-2005 16:21:19 debug cguiinfomanager::setcurrentmovie(rar://z:\temp\,1,,smb://xbox:[email protected]/dvdr-pal/national.lampoons.gold.diggers.2003.nordic.pal.dvdr-dfg/dfg-nlgd.rar,\dfg-nlgd.img)
09-09-2005 16:21:20 debug msg:ffrw:normal play
09-09-2005 16:21:20 debug msg: mplayer_close_file()
09-09-2005 16:21:20 debug msg: uninit_player
09-09-2005 16:21:20 debug deleted yv12 texture (0)
09-09-2005 16:21:20 debug deleted yuv video texture
09-09-2005 16:21:20 debug msg: uninit_player - done
09-09-2005 16:21:20 debug freeing fs segment @ 0x968010
09-09-2005 16:21:20 debug playback has finished
09-09-2005 16:21:20 notice start led control
09-09-2005 16:21:20 notice dim lcd on playback
09-09-2005 16:21:20 debug setting resolution 6
09-09-2005 16:21:20 debug we set resolution 6
09-09-2005 16:21:20 info loading skin file: myvideo.xml
09-09-2005 16:21:23 info activating window id: 10000
09-09-2005 16:21:23 info loading skin file: home.xml
09-09-2005 16:21:24 info loading skin file: playercontrols.xml
