Full Version: Display (text) problem when I install Frodo RC1
Hello,
display (text) problem when I install Frodo RC1. I'm using Vista 64, no problems with previous versions.
Russ
http://forum.xbmc.org/showthread.php?tid=143548
among many other threads on this issue.
problem solved--Compatibility Mode to XP in Properties. Works perfect. Thank you Artafael.
The real fix is the driver update not compat mode http://forum.xbmc.org/showthread.php?tid...pid1255576
and the wiki update that reflects this http://wiki.xbmc.org/index.php?title=XBM...th_AMD_GPU
uNi
Yep, compatibility mode was just a stop-gap measure until AMD put out an updated driver that fixed the problem (as pointed out by uNI above and at the end of the thread I posted above).
I dont even have a AMD system, what's wrong with this "picture"?
haha Wink
uNi
Yes, still on 12.11 Beta 8, might be the reason why.
