Good day all. I've been trolling around trying to learn more about my xios ds. I really only know how to watch movies/show using it. It currently has Eden linux installed and I would like Frodo Linux. I have been searching for install guides or instructions with no luck. Could anyone direct me to or tell me how to upgrade to Frodo?
Much appreciated!
Bull
You're already using Frodo. Eden (v12) does not exist for the Pivos XIOS. The best place to get updates and the status on updates is the Pivos forums, as they will provide you with Pivos-specific linux/xbmc builds. Not sure if they're up to RC1 yet, but unless you know how to compile XBMC from source, I would just wait for their updates.
Do a search over at the pivos forum and there are some user supplied (compiled) update.img's that are working well with frodo. latest I believe is on beta3 but I've tried it and it's working well on an M1 for me!
Awesome. Thanks I will check out that forum and search for that
B
