2012-12-14, 09:09
Im runnng Frodo beta 3 on Win7 Pro and have setup MYSQL, and created the database through XBMC i have created advancedsettings.xml correctly and have a second PC running XBMC that can see the database. But when I try and play a video it says that the file is no longer available. And asks if I want to remove it.
Have I missed anything in the setup process for the second PC? Like adding the sources before copying the advancedsettings.xml into the userdata folder? or scraping the library before adding the advancedsettings.xml file.
I have found a heap of setup guides for the SQL database setup but nothing for the setup of the joining PCs. So any help would be greatly appreciated.
