2015-07-22, 01:43
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
2015-07-25, 08:14
Seems broken here, version 1.1.32 getting script error pretty much every time you click on anything within the add-on. Running on OpenElec v5.0.8 Kodi v14.2 Helix.
Will post a debug log file later.
2015-07-25, 15:03
Hi
Please see the debug log: http://xbmclogs.com/px8ifajqo
Thank you.
13:58:36 T:140538552469248 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.KeyError'>
Error Contents: ('data-watch-now-type',)
File "/storage/.kodi/addons/plugin.video.viki/default.py", line 1000, in <module>
UpdatedVideos(url,name)
File "/storage/.kodi/addons/plugin.video.viki/default.py", line 343, in UpdatedVideos
vtype=divcotent.a["data-watch-now-type"]
File "/storage/.kodi/addons/script.module.beautifulsoup/lib/BeautifulSoup.py", line 613, in __getitem__
return self._getAttrMap()[key]
KeyError: ('data-watch-now-type',)
13:58:36 T:140541200779136 DEBUG: ------ Window Init (DialogKaiToast.xml) ------
13:58:36 T:140538552469248 INFO: Python script stopped
Thank you.
2015-08-08, 03:16
I am also experiencing a script error on openelec 4.2 gotham 13.2. I'm also getting the same error with dramago, another addon that dknight created. Dknight, any suggestion how to fix? Thank you!
2015-08-08, 18:48
I upgraded my openelec to the latest version (5.0.8 - kodi 14.2) and all of Dknight's addons work including viki.
2015-08-09, 03:07
I'll check it out. I'm actually getting errors myself
2015-08-10, 02:37
On Viki "search video" works and that is what I have been using, but the other options on the top screen like "updated tv shows" or "genres" all fail for me.
scott s.
scott s.
2015-08-14, 04:07
same here on windows
2015-08-14, 05:31
I just pushed an update it should fix the problem. I've also added code to try and fix the issue with playing viki from devices with ssl issues. Let me know if it works for you guys
2015-08-14, 09:19
Excellent, playback in Kodi seems to be working again!
2015-08-14, 16:19
Sorry to say it's a no go for me. I mean I cannot even install the repo properly. I managed to get it installed 1st time, then it said it had an update which failed I could initially browse the repo but viki failed to install. I can now see your repo listed but I cannot enable it or browse it.
I'm running Kodi 15.0 on Android 5.0.2
Cheers
Cheers
2015-08-14, 21:02
(2015-08-14, 05:31)dknlght Wrote: [ -> ]I just pushed an update it should fix the problem. I've also added code to try and fix the issue with playing viki from devices with ssl issues. Let me know if it works for you guys
so just re install it from the first post link? Thanks
2015-08-14, 23:19
I can't seem to get anything to install from the repo. Is the repo down??
2015-08-15, 01:33
I think he updated the repo to 1.0.5 and moved his content so if you have an older repo installed it might no longer work. Any way was notified of viki update and got and update ver 1.1.33 no problem. All seems to be working. Thanks again.
scott s.
scott s.
2015-08-15, 02:47
i am getting viki error on ver 1.1.33. using on win10.
