Full Version: Add Network Source Issue
Frodo RC1
Enjoy TV 510B
Chipset Family ARM Cortex A9
Chipset Model Amlogic 8726-M3
Cores 1
Chipset Mhz 1000
GPU Mali400
RAM (MB) 1024
Flash Memory (GB) 4
I'm running into a problem adding a source. If I try to Add Source>Add Network Location>Browse then this window stops responding to the IR Controller (I think you need the mouse pointer at this point). I notice the same sort of behaviour when running XBMC on OS X (you can't use the arrow keys on a keyboard you need the mouse pointer), however, when running XBMC on iOS the IR Controller allows you to navigate through this window.
Unfortunately without being able to add the SMB address of my Airport Extreme the Android box is a bit of a chocolate teapot.
Any advice? I guess I could buy Air Mouse but wondered if I could set-up the Android XBMC to respond to the IR Remote as per iOS?
Can you get us a debug log (wiki) from both the Android box and the OS X box of when you try this and it stops responding? Remote/arrow keys should still work on those cases, so it could be a bug.
Here's the os x xbmc.log with debug enabled from the gui. The android box will take more effort...
http://pastebin.com/aX5398JX
Just to check you know which window I'm having the issue in I've taken a screenshot here:-
https://dl.dropbox.com/u/2768868/path.tiff
