Full Version: Perform an alt+tab on XBMC startup
Hello all. Is there a way to get XBMC to do two alt+tabs when it launches? I launch XBMC from Media Center and maybe 2 out of 5 times, the controller won't work right away. I need to do an alt+tab twice to make it the active window (even though it already looks like the active window at startup). I assume creating and adding a command to an autoexec.py file will do it (similar to what is done with Boxee via the Boxeefocus.exe file I found on the web a while back) but I am not a programmer or a scripter so I'm not sure what to put in there. I'm familiar with scripts a little but I'm not sure what to enter in there in a case like this..
I did some searches on Google and this forum but nobody seems to want to do this. I use a Gigabyte GA-EP45-DQ6 motherboard, Windows 7 64, 8800GTS 512 video card w/ driver 306.97, XBMC 12 RC Frodo, XBMC Integration Setup 1.0 (2.0 seems to not work as well) which is what launches XBMC from Windows Media Center.
Thank you, folks!
I will give that a go. Thank you sir.
