Full Version: Frodo RC1: Are there changes in the keymap?
Hi hi,
after update to Frodo RC1 from xbmc 11 some of my mapped remote buttons changed or doesn´t work any more.
One is for example now an PVR Function, I mapped before my DVD menue on.
Are there changes in the keyboard.xml in Frodo?
If it only doesn't work in LiveTV, then yes - there's a live-TV specific section now. Compare to your old XML and update as needed.
Thanks for the answere but no its not in the live tv, its under normal video. So I see I have to look what happend after update to frodo.
I use a microsoft rc6 remote with some reg changes to map the buttons. When I find the issues I will post it.
