Full Version: FRODO 12 RC : Subtitles are not displayed
I'm trying to get the subtitles on .mkv Movies. The files has subtitles with vlc or mplayer.
I've no erros in xbmc.log. The last 2 lines apperas when i deactivate/activate subtitles :
0:24:16 T:139714933806848 NOTICE: Closing audio device
00:24:17 T:139714933806848 NOTICE: Deleting audio codec
00:24:17 T:139714933806848 NOTICE: Opening audio stream: 1 source: 256
00:24:17 T:139714933806848 NOTICE: Finding audio codec for: 86020
00:24:17 T:139714933806848 NOTICE: Creating audio thread
00:24:17 T:139714665559808 NOTICE: Thread CDVDPlayerAudio start, auto delete: false
00:24:17 T:139714665559808 NOTICE: running thread: CDVDPlayerAudio:Tonguerocess()
00:24:17 T:139714665559808 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
00:24:17 T:139714665559808 WARNING: Previous line repeats 3 times.
00:24:17 T:139714665559808 NOTICE: Creating audio stream (codec id: 86020, channels: 2, sample rate: 48000, pass-through)
00:24:40 T:139714933806848 NOTICE: Closing subtitle stream
00:24:40 T:139714933806848 NOTICE: Opening Subtitle stream: 4 source: 256
I'm on debian 7 x64 with Atom D525 + ION2.
Do you think a soft is missing on my installation ?
make sure that in your screen calibration the subtitles are not set to be outside of the screen...
http://wiki.xbmc.org/index.php?title=Set...alibration...
The cablibration is OK, I've already put the subtitles higher in the screen to be sure :/
I've make a try with openelec 2.95, it's ok. So i continue to check what i miss on my debian .
I made a new install of debian wheezy with FRODO BETA, I've still have the problem.
No errors in the xbmc.log. Is there any package to install in order to get subtitles ? I've got the minimal installation. I stil have a X with xdm and wmfs2.
if its ass subtitle you would need libass.
I've check the libass is already installed. I've make a try with fluxbox to be sure it's not a problem with wmfs, but i've no subtitle too.
Is there a thing like libxosd2 or xosd-bin that xbmc use to display the subtitles ?
Maybe a problem, In fact those line only appears when i disable subtitle. When i active them, there is no log..
00:37:36 T:139757182965504 NOTICE: Closing subtitle stream
00:37:36 T:139757182965504 NOTICE: Opening Subtitle stream: 2 source: 256
00:37:39 T:139757182965504 NOTICE: Closing subtitle stream
00:37:39 T:139757182965504 NOTICE: Opening Subtitle stream: 2 source: 256
00:37:42 T:139757182965504 NOTICE: Closing subtitle stream
00:37:42 T:139757182965504 NOTICE: Opening Subtitle stream: 2 source: 256
(yes, I know this is an old thread)
I assume you're using packages from http://www.deb-multimedia.org/?
If so, it's an incompatibility between the (external) version of ffmpeg used in the deb-multimedia packages and xbmc.
I've submitted a patch to xbmc and to the deb-multimedia maintainer.
