I want a blu ray internal drive for ripping. This will not be on my HTPC so I don't really need software for playing Blu Rays. I almost bought an LG today, but then found a bunch of "fake" 5 star reviews on Amazon. Do I need player software for ripping, I don't think so. Any suggestions, looking to spend $75 or less.
E
(2012-12-18, 04:46)EricHoya Wrote: [ -> ]Hi,
E
I owns several LG BD-ROM. It can rips blu-ray disc with ease....as long as you have blu-ray decrypter, any BD-ROM can rip blu-ray disc....the best decrypter is "
AnyDVD HD"....
Thanks for the advice. I have used anydvd before Among others, but was thinking of using makemkv for blu rays. Sometimes I prefer .isos so I can preserve menu function.
E
(2012-12-18, 05:24)EricHoya Wrote: [ -> ]Thanks for the advice. I have used anydvd before Among others, but was thinking of using makemkv for blu rays. Sometimes I prefer .isos so I can preserve menu function.
E
If you want to preserve all the original contents, ISO is the best....and AndyDVD HD is the best ISO ripper...
how long does it take to rip a blu-ray usually? both to ISO or mkv?
(2012-12-18, 22:57)rip_king Wrote: [ -> ]how long does it take to rip a blu-ray usually? both to ISO or mkv?
Depends on ontouched (around 30 Minutes) or re-encoded ( depends on your machine, but definitely several hours)
mad-max
It take very little time to rip blu-ray compare to transcoding it....
