2012-12-18, 19:14
Hey guys,
a few days ago, I installed XBMCBuntu 12 (Beta 3) on my main computer (Intel/Nvidia setup) and everything worked fine. So I decided to give it a try on my HTPC with the following specs:
AMD Phenom II X4
Asus M4A88TD-M/USB3 (AMD 880G chipset/HD4250 graphics)
Crucial M4 128 GB
Hauppauge WinTV Nova-HD-S2 (worked fine on my main PC)
The installation was already weird. I pressed "Install XBMCBuntu" and while the wizard was loading, it displayed errors about "KVM is disabled by bios" and "firmware could not be loaded".
After that, it loaded a live version of ubuntu where I had to start the installation manually using an icon.
After the installation, I got the same screen again (Ubuntu with graphical interface). XBMC was available as entry in the main menu, but refused to start (no error or something).
So I grabbed the logfiles:
https://dl.dropbox.com/u/18722486/logfiles.zip or as direct links: http://pastebin.com/b9R1eUxA
Is this an openGL/graphics driver issue? Is the integrated GPU suported at all or do I have to buy a dedicated nvidia graphics card?
Thanks in advance and regards,
fabs
AMD Phenom II X4
Crucial M4 128 GB
fabs
