2012-12-18, 22:28
Hi!
First of all I want to thank you for this forum - until now it helped me to solve all issues I had with XBMC.
I recently tried to play mms-streams (mms://). This should be supported in Eden with the help of the ffmpeg library. But when I try to open a .strm file with a link like
mms://a1014.v1252931.c125293.g.vm.akamaistream.net/7/1014/125293/v0001/wm.od.origin.zdf.de.gl-systemhaus.de/none/3sat/12/01/120116_galileo_hitec_h.wmv
the following error occurs:
The ffmpeg library supports mms, I can open the link with mplayer. I built XBMC using the Gentoo ebuild xbmc-11.0-r1. In the whole build process, mms is not mentioned. According to the portage log file the external ffmpeg is used:
Streams using the rtmp protocol or the Youtube plugin work fine.
Any ideas?
Thank's
Stefan
21:03:17 T:3026065136 NOTICE: DVDPlayer: Opening: mms://a1014.v1252931.c125293.g.vm.akamaistream.net/7/1014/125293/v0001/wm.od.origin.zdf.de.gl-systemhaus.de/none/3sat/12/01/120116_galileo_hitec_h.wmv
21:03:17 T:3026065136 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
21:03:17 T:2973772656 NOTICE: Creating InputStream
21:03:17 T:2973772656 NOTICE: Creating Demuxer
21:03:17 T:2973772656 ERROR: OpenDemuxStream - Error creating demuxer
21:03:17 T:2973772656 NOTICE: CDVDPlayer::OnExit()
21:03:17 T:2973772656 NOTICE: CDVDPlayer::OnExit() deleting input stream
21:03:17 T:3026065136 ERROR: Playlist Player: skipping unplayable item: 0, path [mms://a1014.v1252931.c125293.g.vm.akamaistream.net/7/1014/125293/v0001/wm.od.origin.zdf.de.gl-systemhaus.de/none/3sat/12/01/120116_galileo_hitec_h.wmv]
21:03:17 T:3026065136 NOTICE: CDVDPlayer::CloseFile()
21:03:17 T:3026065136 NOTICE: DVDPlayer: waiting for threads to exit
21:03:17 T:3026065136 NOTICE: DVDPlayer: finished waiting
checking ffmpeg/rgb2rgb.h usability... no
checking ffmpeg/rgb2rgb.h presence... no
checking for ffmpeg/rgb2rgb.h... no
configure: == Use of external ffmpeg enabled. ==
configure: Skipping configuration of submodule lib/ffmpeg.
Any ideas?
Thank's
Stefan
