Full Version: Channel Callsigns are used instead of Channel Names
Before I report this as a bug... I wanted to see if anyone else was having this issue. XBMC seems to import my channels correctly except for the channel name. It grabs the Channel Callsign instead of the Channel Name. MythTV supports both [1]. Anyone else seeing this behavior?
[1] http://www.mythtv.org/wiki/User_Manual:M...nel_Editor
I am experiencing the same thing on my NPVR setup. this is the only mention of this that I could find. I know its a different platform but did you ever find your answer to this?
Have you played with the settings in 'General': http://wiki.xbmc.org/index.php?title=PVR/XBMC
If you still see this with the mythtv add-on, provide a log as described here: http://wiki.xbmc.org/index.php?title=PVR/Backend/MythTV --> 4.2
