Full Version: Samsung Tab2 7" - HELP
For the life of me I cannot get my Tab to load the movies from my MicroSD card into XBMC.
I can watch them on the movie player that came on the unit. They are found in "Root" - "extSDcard" - then poof there are the movies
I try and find the directory "extsdcard" in XBMC but it is nowhere to be found. The only thing I can find is "SDcard" which is different.
Can someone walk me through adding files from a MicroSD card? I'm feeling pretty dumb right now.
I click on
- "Add Files"
- "External Storage"?
Under Videos
Select "Files"
select "add videos"
select "browse"
select "root file system"
select "mnt"
select "extsdcard"
That should be where you want to go.
