Full Version: GIT - Smartplayliststuff
@Phil
you say in an other forum that we could test the smartplaylistfunction for AEON Nox 4.0 with git smartplayliststuff version. I get this version fresh from git but every try to add a smartplaylist to custom1 fails. I select in skin Customize - Main Menu item - Custom1 - choose typ - Videoplaylist. Then there is a new window with "Music playlist" and i dont see any playlist. Is this a bug on my side ?
Eisi
Did you have script.playlists ?
This script is needed to display smart playlists.
@mike
Thanks, life could be so simple Smile Now it works.
when i add a widget to the playlist i get and randomandlastitem script error.
http://xbmclogs.com/show.php?id=22902
Eisi
For randomandlastitem, Martijn is working on it :
http://forum.xbmc.org/showthread.php?tid...pid1268608
Post your log on dedicated thread.
As this branch can handle smart playlists, I will have a look.
script isn't fully updated so still lot of small bugs left.
so no reports needed for now
