Full Version: PVR Activate Window
Tested on:
Frodo RC 2
Transparency 5.0.3 skin
Windows 7
I have been looking at a way to be able to jump straight to the EPG: Timeline View and also straight to recordings from the main menu on my home screen
I have been playing around with my favourites .xml and then attaching that as a menu item within transparency but I cannot find the correct window name for either EPG TImeline or Recordings.
Does anyone know them?
Here is what I figured out from playing around with it
mypvr - TV Channels
pvrguideinfo - Programme Info
pvrrecordinginfo- Programme Info
pvrtimersetting - looks broken (maybe a skin problem)
pvrchannelmanager - Channel Manager
pvrguidesearch - Search Guide
pvrosdchannels - Doesn't do anything
pvrosdguide - Doesn't do anything
My first choice was pvrosguide for the EPG but it doesn't seem to do anything
Here is how I am creating the favourite.xml
<favourites>
    <favourite name="EPG View" thumb="someicon.jpg">ActivateWindow(pvrosdchannels)</favourite>
</favourites>
XBMC.ActivateWindowAndFocus(MyPVR, 31,0, 10,0)
By doing a quick search on what you said i came across this topic http://forum.xbmc.org/archive/index.php/...05959.html
The last post in there explains why pvroschannels & pvrosguide don't do anything - there for when video is playing full screen
Here are a bunch of other codes that you posted in there
e = activate EPG = XBMC.ActivateWindowAndFocus(MyPVR, 31,0, 10,0)
h = activate TV = XBMC.ActivateWindowAndFocus(MyPVR, 32,0, 11,0)
j = activate Radio = XBMC.ActivateWindowAndFocus(MyPVR, 33,0, 12,0)
k = activate Recordings = XBMC.ActivateWindowAndFocus(MyPVR, 34,0, 13,0)
b = activate Search = XBMC.ActivateWindowAndFocus(MyPVR, 35,0, 14,0)
Cheers
