Full Version: First Build 1080P 3D suggestions please
Hey all,
This is my first build, I will be running windows 7 32/64 which ever works good with XBMC. What do you think of this build? I will be using the systems for:
1. Streaming all types of content (mkv, m2ts, avi, ISO, etc) including Blu Ray rips (all my content is on a NAS)
2. Download content (via Usenet) - this also means uncompressing downloaded material
3. Serve content to other devices in the house
4. Be very quiet, look good and have excellent performance
5. Windows OS only
6. Play 3D 1080p
7. Play 1080p with HD Dolby/DTS
CPU: i3-3225 with HD4000 $ 144.99
Case: ML03 $ $70
Mobo: AsRock z77 Pro4-M OR AsRock H77M $ 109.99/80.99
Memo: DDR3 4-8GB $ 37.99
PSU: Silverstone SST-ST40F-ES $ 44.99
Total: $ 497.96 / 378.96
Will i run into any surprises with the case? will everything fit in the case?
Thanks in advance.
What case? You didn't mention one.
It will be fine for everything you've mentioned.
case added
You in Canada? Looks like the build (and prices) I am working on right now. Doing the Asus P8H77-M board, I need optical out until I upgrade my receiver for HDMI in for sound.
Yes, I'm in Canada. Are you going ti with same build or similar buid?
Same case, same CPU, different motherboard, different power supply
(2012-12-21, 21:30)Walrus Wrote: [ -> ]Same case, same CPU, different motherboard, different power supply
do you mind sharing what your using for your build?
Asus P8H77-M/CSM motherboard
I3-3225 cpu
ML03B case
FSP400-60 psu
Corsair Vengeance DDR3 4gb ram
3TB WD Green HDD (media files)
Crucial M4 64GB SSD (operating system)
What are you putting windows on? You didn't mention a SSD
