2012-12-22, 21:40
Since I am using my bitstream ability in XBMC I notice dropping connections.
Somtimes it was stopping from the image, but most of the times the audio just stops for a short period (receiver does not detect an audio track) and then it comes back again.
Currently I am searching to see if it is caused by network streaming. Tried ssh, samba and NFS, all the same problem.
Now I wil try to do it by an USB drive. If that also has the problem I can conclude for sure it is my HTPC.
Update:
I used the same movie, only played from an USB drive. Gues what, no glitches at all.
However what is strange is that the network is gigabit, capable of doing 14 megabyte hands down. A movi is like 7 megabyte.
Is this a problem on my HTPC that is cannot progress this data so fast...
With normal DTS and 5.1 I have no problems if I stream via the network
Network test:
Shows that it could not be the structural network speed, I will look for a plotted longer period test to see if there are some strange drops
Update:
Network test:
htpc01:~ # iperf -s -p 65000
Server listening on TCP port 65000
TCP window size: 85.3 KByte (default)
[ 4] local 192.168.178.18 port 65000 connected with 192.168.178.11 port 46617
[ ID] Interval Transfer Bandwidth
[ 4] 0.0-10.0 sec 1.07 GBytes 921 Mbits/sec
[ 5] local 192.168.178.18 port 65000 connected with 192.168.178.11 port 46624
[ 5] 0.0-10.0 sec 1.08 GBytes 923 Mbits/sec
