I use the slide show view for movies and was wondering would it be difficult to move the "watched check mark" from the top left side of screen to the right It overlays with my movie logos?
thanx for the heads-up.
it will be fixed in the next release.
Similar question; I'm using latest eden and transparency and I want to hide/remove the titles at the top of the screen in movie slide view (media flags too, but I figured that one out). I assume changes have to be made in view-slide.xml, but for the life of me I can't find the relevant line of code. If you could point me to it I would be extremely grateful.
Almost forgot, I also want to remove the transparent bits of gui in slide view, no titles or trailer panel or background gui of those bits. A true fanart view, just the case slide and fanart at all times.
