Full Version: TVDB and EpGuides.com: Items not added to library
XBMC v12RC2 (frodo). I am getting the following error when attempting to update my TVShows:
20:26:50 T:139860090279680 WARNING: No information found for item '/mythtv/videos/tvshows/Caprica/', it won't be added to the library.
20:26:50 T:139860090279680 WARNING: No information found for item '/mythtv/videos/tvshows/Burn Notice/', it won't be added to the library.
20:26:50 T:139860090279680 WARNING: No information found for item '/mythtv/videos/tvshows/Buffy the Vampire Slayer/', it won't be added to the library.
20:26:50 T:139860090279680 WARNING: No information found for item '/mythtv/videos/tvshows/Battlestar Galactica (2003)/', it won't be added to the library.
20:26:51 T:139860090279680 WARNING: No information found for item '/mythtv/videos/tvshows/Batman Beyond/', it won't be added to the library.
20:26:51 T:139860090279680 WARNING: No information found for item '/mythtv/videos/tvshows/Anne Of Green Gables 1985/', it won't be added to the library.
20:26:51 T:139860090279680 WARNING: No information found for item '/mythtv/videos/tvshows/Animal Planet Documentaries/', it won't be added to the library.
20:26:51 T:139860090279680 WARNING: No information found for item '/mythtv/videos/tvshows/Angel/', it won't be added to the library.
20:26:51 T:139860090279680 WARNING: No information found for item '/mythtv/videos/tvshows/24/', it won't be added to the library.
If I switch to EpGuides.com, I get different errors (though I suspect related):
20:05:48 T:140416326280960  NOTICE: VideoInfoScanner: Starting scan ..
20:05:56 T:140416326280960 WARNING: FillBuffer: curl failed with code 22
20:05:56 T:140416326280960   ERROR: CCurlFile::CReadState::Open, didn't get any data from stream.
20:05:56 T:140416326280960   ERROR: Run: Unable to parse web site
20:05:57 T:140416326280960   ERROR: GetVideoDetails: Invalid XML file (want <details>)
20:05:57 T:140416326280960   ERROR: GetDirectory - Error getting /mythtv/videos/tvshows/24/S00/.actors
20:05:57 T:140416317888256  NOTICE: Thread Jobworker start, auto delete: true
20:06:02 T:140416326280960  NOTICE: Previous line repeats 1 times.
20:06:02 T:140416326280960   ERROR: Run: Unable to parse web site
20:06:03 T:140416326280960 WARNING: FillBuffer: curl failed with code 22
20:06:03 T:140416326280960   ERROR: CCurlFile::CReadState::Open, didn't get any data from stream.
20:06:03 T:140416326280960   ERROR: Run: Unable to parse web site
20:06:04 T:140416326280960   ERROR: Previous line repeats 1 times.
20:06:04 T:140416326280960   ERROR: GetVideoDetails: Invalid XML file (want <details>)
Does this appear to be an XBMC issue or issues with the two sites? Ay other information you might need?
*EDIT* I thought I should mention that the ovieDB plugon works fine. Unrelated to the two TV plugins I know, but I thought it might be useful to know that if it is an XBMC issue, it is not a "general" one.
-SilkBC
Thetvdb api is not working at the moment. Epsguide must also use some the api that why it must be also not working.
This is the API on the TVDB side you are referring to, I am guessing?
yes...but should be working now
My TV shows are now updating from TVDB. Thanks for whatever you did to fix it.
-SilkBC
