Full Version: TV Scraping woes
Got a problem with the TV Show scraping (movie scraping works just fine)
For some reason (which hopefully is obvious to you guys who understand this kind of thing) none of my TV shows will scrape information.
I rebuilt my htpc last night after installing a new HD, running Windows 8 Pro and XBMC 11 (I initially tried Frodo but had the same issue so uninstalled and installed Eden)
I can scrape Movies with only the odd mismatch (naming issues) however TV Shows will not scrape regardless of what I do.
Naming is (for example)
F:\Media-Player\TV\The Walking Dead\
TVDB shows that this is the correct name for the show, and I've not changed the file structure on this drive between it working on my Windows 7 HD. TV shows would scrape without issue before the upgrade.
I've attached the log file in the hope that I may get a pointer to where this is failing
http://pastebin.com/ZPyb26pn
Any assistance would be greatly appreciated, faffing about with this is not what I had in mind for xmas eve (there's mince pies to be makin !!!!)
The TVDB API stopped working yesterday so, until they get it fixed, you won't be able to scrape new shows into your library with the TVDB scraper add-on. You can monitor this thread on their site for any status updates: http://forums.thetvdb.com/viewtopic.php?f=4&t=12099
