2012-12-24, 17:23
I would like to enable passthrough audio for DTS tracks, which my receiver (logitech Z-5500) is capable of decoding. However, I am unable to find an IEC958 device listed in passthrough audio settings. My sound card is integrated into my motherboard (Asus P5B deluxe). The motherboard has three sets of audio outputs: optical, coax, and the 5.1 channel analog 1/8" jacks. I would like to connect the SPDIF toslink/optical connection to the Z-5500. I am running Debian Wheezy and XBMC 12.0 Frodo.
For Audio Output Devide, I have three options:
(1.) Default (HDA Intel AD198x Analog) <<== This is the only option that will actually play audio files. Nothing else produces sound
(2.) HDA Intel, AD198x Digital S/PDIF
(3.) HDA Intel, AD198x Analog
For Passthrough Output Device, I have only one option (and it will not let me change it)
(1.) HDA Intel, AD198x Digital S/PDIF
The current state of audio:
2 Channel audio works only if DTS / AC3 / AAC is forced to down-convert to two-channel-PCM.
5.1 Channel passthrough does NOT work. It plays a digital "noise."
My understanding is that if I can get IEC958 listed in alsamixer, I should be able to output DTS in passthrough audio. The problem is that IEC958 is not listed in alsamixer.
This is a screenshot of alsamixer, note that there are no sources to the left or the right of the active screen (iec958 is not present at all)
So, please help me diagnose the problem. And as always, thank you for your help!
root@xmbc-streamer:/home/oddworld# aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: Intel [HDA Intel], device 0: AD198x Analog [AD198x Analog]
Subdevices: 0/1
Subdevice #0: subdevice #0
card 0: Intel [HDA Intel], device 1: AD198x Digital [AD198x Digital]
Subdevices: 1/1
root@xmbc-streamer:/home/oddworld# aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
default:CARD=Intel
Default Audio Device
sysdefault:CARD=Intel
front:CARD=Intel,DEV=0
Front speakers
surround40:CARD=Intel,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=Intel,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Intel,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Intel,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Intel,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
[b]iec958:CARD=Intel,DEV=0
IEC958 (S/PDIF) Digital Audio Output[/b]
root@xmbc-streamer:/home/oddworld# lspci
00:00.0 Host bridge: Intel Corporation 82P965/G965 Memory Controller Hub (rev 02)
00:01.0 PCI bridge: Intel Corporation 82P965/G965 PCI Express Root Port (rev 02)
00:1a.0 USB controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #4 (rev 02)
00:1a.1 USB controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #5 (rev 02)
00:1a.7 USB controller: Intel Corporation 82801H (ICH8 Family) USB2 EHCI Controller #2 (rev 02)
00:1b.0 Audio device: Intel Corporation 82801H (ICH8 Family) HD Audio Controller (rev 02)
00:1c.0 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 1 (rev 02)
00:1c.4 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 5 (rev 02)
00:1c.5 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 6 (rev 02)
00:1d.0 USB controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #1 (rev 02)
00:1d.1 USB controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #2 (rev 02)
00:1d.2 USB controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #3 (rev 02)
00:1d.7 USB controller: Intel Corporation 82801H (ICH8 Family) USB2 EHCI Controller #1 (rev 02)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev f2)
00:1f.0 ISA bridge: Intel Corporation 82801HB/HR (ICH8/R) LPC Interface Controller (rev 02)
00:1f.2 SATA controller: Intel Corporation 82801HR/HO/HH (ICH8R/DO/DH) 6 port SATA Controller [AHCI mode] (rev 02)
00:1f.3 SMBus: Intel Corporation 82801H (ICH8 Family) SMBus Controller (rev 02)
01:00.0 VGA compatible controller: NVIDIA Corporation G71 [GeForce 7950 GT] (rev a1)
02:00.0 Ethernet controller: Marvell Technology Group Ltd. 88E8056 PCI-E Gigabit Ethernet Controller (rev 12)
03:00.0 SATA controller: JMicron Technology Corp. JMB363 SATA/IDE Controller (rev 02)
03:00.1 IDE interface: JMicron Technology Corp. JMB363 SATA/IDE Controller (rev 02)
05:03.0 FireWire (IEEE 1394): Texas Instruments TSB43AB22A IEEE-1394a-2000 Controller (PHY/Link) [iOHCI-Lynx]
05:04.0 Ethernet controller: Marvell Technology Group Ltd. 88E8001 Gigabit Ethernet Controller (rev 13)
root@xmbc-streamer:/home/oddworld# lsmod | grep snd*
snd_hda_codec_analog 78059 1
snd_hda_intel 26345 2
snd_hda_codec 78031 2 snd_hda_intel,snd_hda_codec_analog
snd_hwdep 13186 1 snd_hda_codec
snd_pcm 63900 3 snd_hda_codec,snd_hda_intel
snd_page_alloc 13003 2 snd_pcm,snd_hda_intel
snd_seq 45093 0
snd_seq_device 13176 1 snd_seq
snd_timer 22917 2 snd_seq,snd_pcm
snd 52850 11 snd_timer,snd_seq_device,snd_seq,snd_pcm,snd_hwdep,snd_hda_codec,snd_hda_intel,snd_hda_codec_analog
soundcore 13065 1 snd
